2022 CUBE Kathmandu Hybrid ONE 500 Review
Highlights
Technical Specs & Ratings
General
2022
$4,099
Class 1
High-Step,Mid-Step,Step-Thru
Front Suspension
28.0
10
Hydraulic Disc
Mid-Drive
250
500 Wh
500 Wh
56.1 lbs / 25.47 kgs
Components
M/Z: ACROS AZF-1039, 1 1/8" straight, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) // EE: ACROS AZX-1041, BlockLock 135°, 1 1/8" straight, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm)
CUBE Comfort Stem Pro, 31.8mm, Adjustable
CUBE Comfort Trail Bar, 700mm
Natural Fit Comfort
CUBE Suspension Seatpost HD, 30.9mm
30.9
Natural Fit Sequence Comfort
ACID PP Trekking
Hydraulic Disc
Shimano BR-MT200, Hydr. Disc Brake (180/180)
Video Reviews
Written Reviews
The Cube Kathmandu Hybrid ONE 500 Diamond Tour eBike is a versatile electric bike that can handle any journey, whether it's across town or the state. Here are some of the key features of this electric bike:
Bosch Drive Unit: The Cube Kathmandu Hybrid ONE 500 is equipped with Bosch's fourth-generation drive unit, which provides a smooth and powerful ride. The Performance Line CX drive unit is designed for off-road use and provides up to 85 Nm of torque.
High-Capacity Battery: The Cube Kathmandu Hybrid ONE 500 has a high-capacity 500Wh battery that provides plenty of power for long rides. The battery is integrated into the frame for a sleek and streamlined look.
Shimano Gears: The Cube Kathmandu Hybrid ONE 500 features Shimano's easy-to-use and reliable 1x10 gears. The Shimano Deore RD-M4120-SGS rear derailleur and Shimano Deore SL-M4100 Rapidfire-Plus shifters work seamlessly together to provide smooth and precise shifting.
Suntour Suspension: The Cube Kathmandu Hybrid ONE 500 is equipped with a Suntour suspension fork and suspension seatpost, which provide a comfortable ride even on rough terrain. The stem is adjustable to allow you to customize the fit for maximum comfort.
Hydraulic Disc Brakes: The Cube Kathmandu Hybrid ONE 500 features Shimano BR-MT200 hydraulic disc brakes, which provide reliable stopping power in all conditions.
Comfortable Handlebar and Grips: The Cube Comfort Trail Bar and Natural Fit Comfort grips provide a comfortable and ergonomic grip for long rides.
Integrated Lighting: The Cube Kathmandu Hybrid ONE 500 has integrated lighting, including a front and rear light powered by the main battery. This provides visibility and safety in low-light conditions.
Aluminum Frame: The Cube Kathmandu Hybrid ONE 500 has a lightweight and durable aluminum frame. The frame has efficient comfort geometry and a tapered headtube for a comfortable and stable ride.
Post a Comment for 2022 CUBE Kathmandu Hybrid ONE 500
