2022 CUBE Kathmandu Hybrid Pro 625 Review
Highlights
Technical Specs & Ratings
General
2022 |
Kathmandu Hybrid Pro 625 |
$4,199 |
Class 1 |
High-Step,Mid-Step,Step-Thru |
Suspension Type |
Front Suspension |
28.0 |
11 |
Hydraulic Disc |
Mid-Drive |
250 |
625 Wh |
625 Wh |
58.08 lbs / 26.37 kgs |
Frameset
58.08 |
Suspension Type |
Front Suspension |
100 |
X-Fusion MIG32 Air, Tapered, 15x110mm, 100mm, Lockout |
CUBE EX23, 36H, Disc, Tubeless Ready |
Schwalbe Big Ben, Performance, 55-622 |
Drivetrain
11 |
Shimano Deore SL-M5100, Rapidfire-Plus |
ACID E-Crank, 38T, 175mm (EE: 170mm) |
Shimano Deore RD-M5100-SGS, 11-Speed |
Shimano Deore CS-M5100, 11-51T |
Components
M/Z: ACROS AZF-1038, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) // EE: ACROS AZX-1040, BlockLock 135°, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) |
CUBE Comfort Stem Pro, 31.8mm, Adjustable |
CUBE Comfort Trail Bar, 700mm |
Natural Fit Comfort |
CUBE Suspension Seatpost HD, 30.9mm |
30.9 |
Natural Fit Sequence Comfort |
ACID PP Trekking |
Hydraulic Disc |
Shimano BR-MT200, Hydr. Disc Brake (180/180) |
Ebike Systems
Class 1 |
Mid-Drive |
Bosch Drive Unit Performance CX Generation 4 (85Nm) Cruise (250Watt) |
250 |
Bosch Intuvia |
625 Wh |
625 Wh |
Bosch PowerTube 625 |
Bosch 2A |
Accessories
Front: CUBE Shiny 50 Lux, 12V, DC | Rear: ACID Mudguard Rear Light PRO-E, 12V, DC |
ACID 65 BB-Mount |
CUBE Integrated Carrier 2.0, ACID RILink Adapter Compatible, SnapIt Compatible |
More Details
United States, Canada, Europe |
2 Years Motor and Battery, 5 Years Frame |
Diamond: S (50cm), M (54cm), L (58cm), XL (62cm); Trapeze: XS (46cm), S (50cm), M (54cm); Easy Entry: XS (46cm), S (50cm), M (54cm), L (58cm) |
Flashgrey’n’Black |
KMC X11 |
Shimano HB-MT400-B, 15mm, Boost, Centerlock |
Shimano FH-TX505, QR, Centerlock |
CUBEstand Cmpt |
Easy Bell |
Local Shops that Carry
Official Shop for
Online Shops that Carry
Video Reviews
Written Reviews
The CUBE Kathmandu Hybrid Pro 625 eBike is a versatile, comfortable electric bike.
The Kathmandu Hybrid Pro 625 features a fourth-generation Bosch drive system and a 625Wh battery, providing a power boost to your ride. The X-Fusion air suspension fork with lockout allows for easy adjustability, while the suspension seatpost and adjustable stem provide added comfort, even on rougher roads.
The Shimano Deore derailleur provides 1x11 gears, giving it a vast range. Fingertip shifting makes it easy to find the right gear for any terrain.
The bike also comes with a full complement of accessories and a sturdy Integrated Carrier, making it easy to take any trip in your stride.
Post a Comment for 2022 CUBE Kathmandu Hybrid Pro 625
Comment has been submitted successfully.
Comment is being held for moderation and will be posted after it has been reviewed
