2022 CUBE Reaction Hybrid Performance 500 Allroad Review
Highlights
Technical Specs & Ratings
General
2022 |
Reaction Hybrid Performance 500 Allroad |
$2,549 |
Class 1 |
High-Step |
Suspension Type |
Front Suspension |
27.5,29.0 |
9 |
Hydraulic Disc |
Mid-Drive |
250 |
500 Wh |
500 Wh |
53.68 lbs / 24.37 kgs |
Frameset
High-Step |
53.68 |
Suspension Type |
Front Suspension |
100 |
SR Suntour NVX30 Coil, 100mm |
Rodi Blackrock 23, 32H, Disc, Tubeless Ready |
Schwalbe Smart Sam, Active, 2.35 |
Drivetrain
9 |
Shimano SL-M3100-R, Rapidfire-Plus |
ACID E-Crank, 175mm, 38T |
Shimano RD-M3100-SGS, 9-Speed |
Shimano CS-HG201, 11-36T |
Components
27.5: ACROS AZX-1041, BlockLock 135°, 1 1/8" straight, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) // 29: ACROS AZF-1039, 1 1/8" straight, Top Zero-Stack 1 1/8" (ZS 44mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) |
CUBE Performance Stem Pro, 31.8mm |
CUBE Rise Trail Bar, 720mm |
CUBE Race Grip 31mm, 1-Clamp |
CUBE Performance Post, 30.9mm |
30.9 |
Natural Fit Sequence |
CUBE PP MTB |
Hydraulic Disc |
Shimano BR-MT200, Hydr. Disc Brake (180/180) |
Ebike Systems
Class 1 |
Mid-Drive |
Bosch Drive Unit Performance Generation 3 (65Nm) Cruise (250Watt) |
250 |
Bosch Purion |
500 Wh |
500 Wh |
Bosch PowerTube 500 |
Bosch 2A |
Accessories
Front: CUBE Shiny 50 Lux, 12V, DC | Rear: ACID Mudguard Rear Light PRO-E, 12V, DC |
ACID 65 BB-Mount |
More Details
United States, Canada, Europe |
2 Years Motor and Battery, 5 Years Frame |
Size Split: 27.5: XS (13.5"), S (15") // 29: M (17"), L (19"), XL (21"), XXL (23") |
Shinyapple´n´Black, Metallicgrey´n´White |
KMC X9 |
Shimano HB-TX505, QR, Centerlock |
Shimano FH-TX505, QR, Centerlock |
CUBEstand Cmpt |
Easy Bell |
Local Shops that Carry
Official Shop for
Online Shops that Carry
Video Reviews
Written Reviews
The Reaction Hybrid Performance 500 Allroad eBike by CUBE is a high-performance electric bike that can take you off the beaten path. This bike is equipped with Bosch's third-generation drive system, which provides plenty of power. Bosch's PowerTube design ensures that the battery is well-protected and easy to access when it needs to be charged.
The Shimano 9-speed gears are easy to use and provide a wide range of options for various terrains. The wider saddle and lock-on grips are designed to make you comfortable on long rides, while the 100mm Suntour suspension fork smooths the ride on rough terrain. The Shimano hydraulic disc brakes provide reliable stopping power in all weather conditions.
The Reaction Hybrid Performance 500 Allroad is designed for riders who want to explore new trails on mixed terrain. The bike is built with quality components designed to withstand the rigors of off-road riding. The frame is made from lightweight aluminum, which makes it easy to handle and maneuver.
The bike's geometry is optimized for off-road riding, with a slack head angle and a longer reach to provide stability and control on steeper descents. The bike's wheelbase is also longer to offer more stability at high speeds.
Post a Comment for 2022 CUBE Reaction Hybrid Performance 500 Allroad
Comment has been submitted successfully.
Comment is being held for moderation and will be posted after it has been reviewed
