2022 CUBE Stereo Hybrid 120 Pro 625 Review
Highlights
Technical Specs & Ratings
General
2022 |
Stereo Hybrid 120 Pro 625 |
$5,099 |
Class 1 |
High-Step |
Suspension Type |
Full Suspension |
27.5,29.0 |
12 |
Hydraulic Disc |
Mid-Drive |
250 |
625 Wh |
625 Wh |
55.88 lbs / 25.37 kgs |
Frameset
High-Step |
55.88 |
Suspension Type |
Front Suspension |
120 |
RockShox Deluxe Select, 185x55mm (27.5: 165x45mm), Rebound Adjust, Trunnion Mount, Top: 54mm Trunnion Mount, Bottom: 30x8mm |
RockShox Recon Silver RL Air, Tapered, 15x110mm, eMTB Approved, 120mm, Lockout |
CUBE EX30, 32H, Disc, Tubeless Ready |
Schwalbe Smart Sam, Active, 2.6 |
Drivetrain
12 |
Shimano Deore SL-M6100-IR, Direct Attach, Rapidfire-Plus |
ACID E-Crank, 170mm, 38T |
Shimano Deore RD-M6100-SGS, ShadowPlus, 12-Speed |
Shimano Deore CS-M6100, 10-51T |
Components
27.5: ACROS AZX-1032, BlockLock 120°, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) // 29: ACROS AZX-1030, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) |
CUBE Performance Stem E-MTB, 31.8mm |
Newmen Evolution SL 318.25, 760mm |
Natural Fit All Terrain |
CUBE Performance Post, 30.9mm |
30.9 |
Natural Fit Sequence |
CUBE PP MTB |
Hydraulic Disc |
Shimano BR-MT420, Hydr. Disc Brake (203/203) |
Ebike Systems
Class 1 |
Mid-Drive |
Bosch Drive Unit Performance CX Generation 4 (85Nm) Cruise (250Watt) |
250 |
Bosch Purion |
625 Wh |
625 Wh |
Bosch PowerTube 625 |
Bosch 2A |
Accessories
More Details
United States, Canada, Europe |
2 Years Motor and Battery, 5 Years Frame |
Size Split: 27.5: XS (15"), S (17") // 29: M (18"), L (20"), XL (22") |
Skyblue’n’White |
Shimano CN-M6100 |
Shimano HB-MT400-B, 15mm, Boost, Centerlock |
Shimano FH-MT410-B, 12mm, Boost, Centerlock |
Local Shops that Carry
Official Shop for
Online Shops that Carry
Video Reviews
Written Reviews
The Stereo Hybrid 120 Pro 625 Full Suspension Mountain eBike by Cube Bikes is a high-performance electric bike designed for trail use.
It features a comfortable, ground-hugging suspension system with 120mm of travel in the fron fork, providing intuitive handling and reliable performance. The bike is equipped with Bosch's fourth-generation CX drive unit and a 625Wh battery, which gives ample power. The Shimano Deore 1x12 gears are easy to use and provide smooth shifting.
The bike also features four-piston hydraulic disc brakes with oversized rotors on both the front and rear wheels, ensuring you are always in control. The Schwalbe 2.6in tires provide excellent grip, and the RockShox suspension system on both the front and rear wheels keeps the bike stable.
The bike's geometry is designed to provide a comfortable and stable ride, with a slack head angle and a long reach.
Post a Comment for 2022 CUBE Stereo Hybrid 120 Pro 625
Comment has been submitted successfully.
Comment is being held for moderation and will be posted after it has been reviewed
