2023 Electra Townie Go! 8D EQ Step-Thru Review
Highlights
Technical Specs & Ratings
General
2023
$2,449.99
Class 1
Mid-Step
26.0
8
Hydraulic Disc
Mid-Drive
250
400 Wh
400 Wh
49.5 lbs / 22.47 kgs
Components
1 1/8" steel threaded/semi-integrated
Forged alloy 25.4mm quill, 80mm extension
Alloy custom bend 25.9" width/4" rise
Electra hand-stitched leatherette
Alloy straight post 27.2x350mm
27.2
Ergonomic w/shock-absorbing elastomers
Resin platform w/non-slip rubber tread
Hydraulic Disc
Front/rear: Tektro mechanical disc brakes| Rotor: Front: 180mm, rear: 160mm
Video Reviews
Written Reviews
The Townie Go! 8D EQ Step-Thru is a versatile electric bike with the following features:
Step-Thru Frame: The bike features a step-thru frame designed to make it easy to mount and dismount, especially for riders with limited mobility or flexibility.
Frame and Fork: The bike features a 6061-T6 aluminum frame with patented Flat Foot Technology®, providing a comfortable and upright riding position. The Hi-ten steel unicrown fork with straight/tapered leg ensures stability and control.
Wheels and Tires: Equipped with 26" anodized alloy rims and 26×2.35" balloon tires, the Townie Go! 8D EQ Step-Thru offers a smooth and stable ride.
Drivetrain: The electric bike comes with a Shimano Acera Rapid Fire Plus shifter, Shimano Tourney TX 8-speed rear derailleur, and a forged alloy crank with a 38t FSA chainring, ensuring smooth and reliable gear changes.
Brakes: The bike has Tektro mechanical disc brakes, providing reliable stopping power in various conditions.
Motor and Battery: The Townie Go! 8D EQ Step-Thru features a Bosch Active Line 250-watt motor and a Bosch PowerPack 400 battery, offering efficient pedal assistance and a range suitable for long rides.
Lights and Accessories: The electric bike comes with Spanninga LED front and rear lights, ensuring visibility and safety during low-light conditions. It also includes a kickstand, reflective battery decal, ring lock mounts, painted chainguard, and internal cable routing.
Weight and Size: Weighing 49.5 lbs, the bike has weight limit of 300 pounds. It is available in a frame size suitable for riders with a height range of 4'11" to 6'1".
Post a Comment for 2023 Electra Townie Go! 8D EQ Step-Thru
