2023 Electra Townie Path Go! 10D EQ Step-Over Review
Highlights
Technical Specs & Ratings
General
2023
$3,849.99
Class 1
Mid-Step
27.5
10
Hydraulic Disc
Mid-Drive
250
500 Wh
500 Wh
55 lbs / 24.97 kgs
Components
1 1/8" steel threaded/semi-integrated
Forged alloy 25.4mm quill, 80mm extension
Alloy custom bend 25.9" width/4" rise
Electra Townie custom ergo kraton w/alloy locking collars
Alloy micro-adjust 27.2x400mm
27.2
Selle Royal Electra gel comfort saddle w/shock-absorbing elastomers
Resin platform w/grip tape tread
Hydraulic Disc
Front/rear: Shimano hydraulic disc brakes| Rotor: Front/rear: 180mm
Ebike Systems
Class 1
Mid-Drive
Bosch Performance Line, 250 watts
250
Bosch SmartphoneHub
Bosch SmartphoneHub, COBI.Bike App, Bluetooth
ABUS frame lock
500 Wh
500 Wh
Bosch PowerTube 500
5 AMP charger
Video Reviews
Written Reviews
The Electra Townie Path Go! 10D EQ Step-Over electric bike IS known for its comfort, ease of use, and performance. Here are the key features of this electric bike:
Frame and Wheels: The frame is made of Townie 6061-T6 aluminum with patented Flat Foot Technology®, providing a comfortable and ergonomic riding position. It features an alloy fork with straight/tapered leg for stability and control. The bike has 27.5" double-walled alloy rims and Bontrager E6 Hard-Case Lite tires, offering puncture resistance and reflective stripes for enhanced visibility.
Drivetrain: The Shimano Deore Rapid Fire Plus shifters and rear derailleur provide smooth and precise gear changes. The bike is powered by a Bosch Performance Line 250-watt motor and a Bosch PowerTube 500 battery, offering reliable and efficient assistance.
Components: The saddle is a Selle Royal Electra gel comfort saddle with shock-absorbing elastomers for a plush and supportive ride. It comes with a Bosch SmartphoneHub controller, Supernova front and rear lights, and a rear MIK compatible rack for added convenience and safety.
Brakes and Accessories: The Townie Path Go! 10D EQ Step-Over is equipped with Shimano hydraulic disc brakes for reliable stopping power. It features a kickstand, ABUS frame lock, and internal cable routing for a clean and organized look.
Additional Details: The bike weighs 25 kg (55 lbs) and a maximum weight limit of 300 pounds (136 kg). The Bosch SmartphoneHub allows for connectivity and control, although some users have reported issues with the smartphone app pairing.
Post a Comment for 2023 Electra Townie Path Go! 10D EQ Step-Over
