48V x 1000W Conversion kit on MTB
#1
I was originally going to use this conversion kit to electrically power a Filipino style pedicab. After posting and getting advice from members here, I realised that I had a lot more to learn so decided to postpone the pedicab project and first convert my 26" MTB to an e-bike.
The conversion kit was a done deal. I bought it on special from China on for about USD260 (including delivery to Cebu, Philippines) rather than the normal price of USD380 - no returns and no warranty. The kit arrived today. The kit consists of:
  • 48V x 1000W brushless non-geared hub motor on a 26" x 1.75" alloy wheel with 6-speed freewheel sprockets
  • 48V x 1000W control box
  • 2 x brake levers with electronic cut-outs
  • 5-magnet PSA unit
  • Thumb type speed control
  • Bag for batteries
  • All associated wiring with 35A fuse.
I need to provide the batteries, charger and a rear carry rack for the batteries.
Overall the quality appear to be very good for the price.
The MTB this is to be fitted on has 26" wheels, alloy frame, 3 x 7 speeds chain gears, disk brakes. I also purchased this on special from China for a little under USD150 (including delivery to Cebu. Philippines).
More tomorrow on what I have discovered and some of the initial problems that (I think) I have solved.
So far, I have not had much free time to play with the conversion kit.
I played around with the handlebar controls and am satisfied that I can position everything to my liking.
A couple of spokes on the hub motor wheel were loose so I had my local bicycle mechanic reset all the wheel's spokes and check that the wheel was "true". He charges like a wounded bull at USD2 per hour!
I have ordered a rear carry rack (USD20 incl. delivery) that should arrive in a week or two from China. It is of aluminium alloy and rated for 35kg load so should be strong enough to support 4 x 12VDC x 20Ahr sealed AGM batteries. I also ordered a 40VDV 20Ahr lead-acid battery charger that should arrive today (USD17.50 incl. delivery).
The hub motor comes with 6 chain sprockets while my MTB is set up with 7 chain sprocket on the rear hub. I am hoping this this will not be a problem if I can suitably adjust the rear derailleur.
There is no provision on the hub motor to directly bolt on a disk brake rotor, however the left- hand side of the hub has an M35x1.5 threaded spigot. This is the same arrangement that is on my MTB. The disk brake rotor can be unscrewed from the hub on my MTB and it screws directly onto the hub motor spigot. Rather than using the disk brake rotor from my MTB, I have ordered another for USD6.50 (incl. delivery) that should arrive in a couple of weeks from China.
I am a bit concerned about using the supplied battery bag that came with the conversion kit. The day-time temperature here is Cebu are a constant 29deg C to 32deg C throughout the year. I am not sure if using the batteries in the bag will be detrimental. Your thoughts on this would be appreciated.
This weekend, I will look into sourcing the 4 x 12VDC x 20Ahr sealed AGM batteries locally and I will play around with fitting the PAS to the MTB's pedal crank.
The cost so far (in USD incl. delivery where applicable):
MTB = $133
Ebike conversion kit = $253
Spoke adjustment = $2
Battery charger = $18
Rear carry rack = $20
Disk brake rotor = $7
Total so far = $433
harryS
I don't look forward to it, but expect a future post about the welds in your alloy rack snapping off from the weight of four SLA batteries. Good for testing the system anyway, Don't hit any bumps.
Another failure is the forward struts on the racks coming loose off the bike. Twice, I've had that happen and the racks tips backward. Part of my morning check now,
#5
HarryS, thank you for the warning.
Rather than use the rear rack shown above, I purchased a different type with a higher load rating for USD20 (incl. delivery from Manila).
This rack is rated for a 25kg load. I loaded it to 80kg (static) without any noticeable deformation, so it should be good fo at least 25kg load (dynamic) while riding. The battery pack to be carried on the rack has a total mass of 19.2kg.
I have decided to change tack - again - on this project.
I originally bought an aluminium alloy frame MTB that I intended to convert to an ebike. Since then, I have set that bike up so well that I really enjoy riding it with pedals only. After a long think, I have decided to buy a cheap(er) steel frame MTB for this conversion project. Cost is USD112 (including delivery from Manila).
Having a steel frame, this new bike should be more resistant to stress cracking. It will also allow to more easily "hack" the bike while I experiment with the conversion. This steel frame bike is basically the same as my aluminium frame bike and should arrive early next week.
The batteries arrived from Manila yesterday.
MTB (steel) = $112
Batteries (4x12V 16Ahr) = $97
Total so far = $509
Dozens of steel MTB frames go to the dump every garbage day. Don't you have any access to the scrap trucks driving around? Or a charity resale shop or something? I realize 2nd world countries are different, but buying common trash new is tough on the environment. I had to buy my aluminum bike new, but I've had a half dozen used MTB frames that I've ridden and ditched. I bought one new MTB in 1985, wore the sprocket totally out and couldn't buy or get off (stuck) any more to match (15 speed). Warning, the 18 speed MTB the rear axles break, axle too thin. 5 & 7 speed axles are thicker.
#8
Indianajo, there is no such thing as a "garbage day" or charity shops in the Philippines like you have in developed countries. There are a few second-hand MTB's locally available (I found 15) but the cheapest was for sale at the same price as I could buy my new steel frame bike (including delivery from Manila). I decided on the new as hopefully there will be less chance of any defects.
#9
It's a shame your scrap merchants are so stingy. At least you looked around to try to find a recycled cycle.
I saw a MTB frame with both front and rear suspensions for $85 at Salvation Army resale Wednesday. Only, I need a stretch frame cargo bike, or I would have bought & electric converted it.
