7 things you want to know about electric bike
There are many types electric bike on ebike market. According to using way, there are mountain assistance electric bike, road power assistance electric bike, long-distance power assistance electric bike. And classified by type of motor, it include hub motors and Mid-mounted motors. This post will tell you seven things what you want to know about electric bike.
Why do you need an electric bike?
Maybe you just need a transportation, cycling it to commute or shopping help you save time to do other things. Maybe you just want to buy one bike can ride on all kind terrains, provide more power and climbing ability, help you faster, smoother and easier to reach top of the mountain, distant valleys and anywhere you want to reach. Maybe you just want to buy an electric bike and ride with friends. Everyone have different reasons to need an electric bike, but it is no doubt that electric bike is a good helper for people. According to different living surrounding and requirements, electric bike have different types.
Post image
Is electric-powered bikes heavy?
Of course, electric bikes will heavier than normal bike because of motor and battery. But during actually riding process, because the power addition of the electric power assist, so you do not feel the electric bike too heavy. Usually each electric bike weight not over 21-25kg, but some electric bikes equipped with a big power motor, the electric bike weight will be over 25kg. It is would be a problem without electric power assist. But some electric bikes weight are light depend on their frame material, like Shuangye have one model road electric bike (A6-R) is light weight with aluminum alloy, and you can lift it easily.
Where can I riding electric bike?
It is need to query your local legal, some countries legal prohibit riding electric bike or limited speed or limited motor power on the road. So you need to know your country or state legal clearly. Like European countries, some of them limit the power of electric bike. According to the different using way, different types of electric bike can meet their different needs. Someone want to buy an electric bike to commute, someone want to buy an electric bike to riding challenge or riding outside long time.
Based on these two situation, we commend classic frame city electric bikes and portable folding electric bikes for those who need to get out or commute easily. for example, Shuangyen A1-7 and A3AL24. For outside riding, fat tire electric bikes and mountain electric bikes are the best choice. Fat tire wheel and high power motor assist you easy to ride on different terrains, and mountain ebike is the best chioce for outside riding. Maybe Shuangye A7AT26 and A6AH26 are suitable for you.
Post image
Which electric bike should I choose?
First of all, you need to consider the material of electric bike frame. Mostly electric bike would use aluminum for they are light, corrosion resistance and durability. So does Shuangye electric bike. And you need to pay attention to other parts, like brake, some electric bike would use V-brake, some would use disc brake. Usually disc brake is better and safer than V-brake, but if just meet daily cycling, V-brake is enough for you. Tire is also a main part, Shuangye electric bike use KENDA tire help reduce replacing times and provide a comfortable riding experience. A smart controller as a bridge to manage electric bike motor, battery, LCD and other electronic parts. Therefore a excellent electric bike must made of high quality material and components.
Post image
Now it is no a easy thing to research and develop an electric bike, it need to spend a lot of time and energy to do it. For example Shuangye electric bike.
Motor
Motor - electric bike core part - is an important consideration reason when people want to an ebike. As we all know, a high power motor means that ebike will provide you more power and fast speed. And there are three types about electric bike motor, mid-drive motor, rear hub motor and front hub motor. More of electric bikes often use rear hub motor, as same as shuangye electric bikes, but a few of electric bikes will installed mid-drive motor which is make you replace ebike wheels more convenient. Front hub motor is no popular on electric bike marketing. So it is few front hub motor electric bike.
Transmission system
Most of electric-assisted electric bikes are not much different from the “traditional” electric bikes on the transmission system. However, with the development of motorcycles, accessories dedicated to electric power products will become more and more common. Shuangye electric bikes use SHIMANO transmission system which designed to provide an optimized E-MTB gear ratio range, as well as increased battery life and reduced part wear. And it is also possible to convert the SHIMSNO transmission system with mechanical shifting. Changing different gears depend on your riding situation.
Battery
How long dose electric bike charge a single charge? Usually battery decide how long motor operating time. So a large capacity battery means operating ling time. And Shuangye electric bike provide 36V/48V 9AH/10AH adapt to your need of long-distance. It can be fully charged with a dedicated charger for 4-6 hours and can be riding 40-60km. According to different requirements, and you can choose different types electric bike batteries, like hidden batteries, bottle batteries, triangle batteries, frog batteries and other. And combine with PAS system mode to help you save more electric.
PatriciaK
As a former ESL instructor, I understand that foreign language speakers tend to use the grammatical framework of their own language, much as native English speakers do when attempting to speak another language. For sales and support of English-speaking customers, though, it would be beneficial to the company to employ a fluent English speaker to edit their print materials. It's off-putting to potential customers to try to make sense of this text.
Mtl_Biker
Besides the poorly written text, I think this is a sneaky way to inject advertising/promotional material to the forum. If that manufacturer had a dedicated forum section here, then the text should go there (if even allowed) but I feel it shouldn't be in the intro section.
