Alexrims MD21 What size tire? 26", 27.5", 29"
Johnitahoe
I'm trying to replace the tires on my Hai Bike 2008 Cross with something more durable and aggressive.
I understand tire width and what the rims will accommodate, but don't understand tire size. Which I guess is diameter?
The RIMS are 622x21. What size tire should I purchase?
Thanks,
John
FlatSix911
I understand tire width and what the rims will accommodate but don't understand tire size. Which I guess is diameter?
Thanks,
John
The short answer... you rims are 622mm in diameter and 21mm in width.
You can select a range of tires that are 700mm or (28-29") in diameter with a 25-50mm width (1-2")
Hope this helps and let me know if you need any additional information on tire recommendations.
E-Wheels
Thanks,
John
Good information can be found here under the Technology tab
https://www.schwalbetires.com/tech_info/size_markings
