I have a RadWagon that came with mechanical disc brakes. With my additional front motor , 2 cargo bags attached, and second battery, bunch of tools, occasional 17 inch laptop, and 3 sets of clothes (for the gym, for work, for the ride back) the bike comes in at 135+ lbs.
I can adjust the rear brakes to stop but it takes effort (4 fingers) to stop the bike with just the rear brakes. With the front and rear it can stop pretty quickly.
I wanted to upgrade the rear to hydraulic brakes, but then I wouldn't know how to attach the motor cut off. The system isn't Bafang so I can't just buy the magnets. I came across this hybrid setup where use you can use the existing brake levers and cable, but uses oil in pressing the brakes.
Does anyone have experience with this unit?
https://www.amazon.com/TRP-Cable-Actuated-Hydraulic-Brake-Black/dp/B074ZHZZ5D/ref=sr_1_2?ie=UTF8&qid=1514399346&sr=8-2&keywords=trp+hydraulic+brakes
Also, can this be used with a 180 mm disc? What type of adapter would I need?
Would this adapter work?
https://www.amazon.com/160mm-180mm-Adapter-Bracket-Standard/dp/B01KA2MPNW/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1514401573&sr=1-3&keywords=180mm+brake+adapter&th=1&psc=1
thanks,
William
thanks,
William
