Custom voltmeter
Oldbkr
Here's my custom meter I put together for quick post ride checks before charging .I bought the meter on EBay, built the case and wired up to the connector I bought a couple of weeks ago. ?20180830_154156.jpg
MetroDuck
I'm curious. Do you get a matching voltage reading on the display? I would thing that you should give or take 1/10 volt.
Oldbkr
I had to rig this up because the C7 display panel does not have a voltage display function. I have found out other Magnum models do have that ,which I must admit I envy.?
Oldbkr
I'm not that worried about realtime voltage. I rely on the indicator bars and my time vs voltage decrease experience with my Ui6. My main concern was a quick check before timing my charge to somewhere near 80%....thanks for the idea in case I change my mind in the future?
