Haibike brake cables rattling inside frame
#1
Hi folks
I've got a Xduro Fullseven 2017 5.0 full suspension. The rear brake and gear cables run into the frame and are rattling inside over bumps etc. Tried a few different things but so much movement from the suspension the cables move around alot.
Any thoughts?
Thanks
Brooks
Your hearing is better than mine.. I don't hear that.
I guess go to hardware store and buy some rubber o-rings, take cables apart and slip o-rings down cable casing into frame.
rich c
My thought exactly! If you can hear the brake hose and plastic coated gear cable over the SES chain system, you must have super powers! My Full Seven is a 2016.
#5
I think it's possible the cable ties inside the frame are knocking against the edge as you can pull on them and they make the knocking noise, i can't get to them without pulling the whole cables out which I guess is a option. There's a great deal of
What i've tried in the past is just filling the tube with bubblewrap to stop as much movement but slips down after a while.
#6
My solution was to put cable ties every few inches and then don't cut the tails off. Rotate them around the cable. then slowly feed the cables into the frame.. the ties either hold the cable away or up against the frame.. either way the rattling stops. the other way is to Just go faster and let the wind noise drown out all other noises.. this second way has solved the noises non ebikers make when you pass them on the left.
