Haibike FS RX Kick Stand
Scooteretti
Hello Dwight,
Congrats on the purchase you will certainly love it. The bike should have come with a cast bracket (black color if a 2015) + 2 bolts/screws. This will mount to the rear of the bike on the non drive side (you will see the mounting points. Then you add a stand like this one here to it.
As the mounting bolt hole diameter on the cast bracket is different than the hole size on the stand, we simply just increase the hole diameter on the stand slightly (easy to do as the aluminum is quite soft) to accommodate the larger size bolts diameter on the cast bracket.
Feel free to PM me if you need more info.
Will
