How to calculate maximum initial acceleration of the motorcycle?
SamZ
Motorcycle Specifications:-
Top speed:- 170 Km/h
0-100 Km/h Time:- 3.5 Sec
Motor Used:- 20KW Cont / 50KW Peak // ~50Nm Continuous / 120Nm Peak
Tire Size:- 120/70-17 front and 160/60-17 rear
Motorcycle weight:- 190 Kg
Motor sprocket - 11T
Wheel sprocket - 64T
Assuming the rider weight as 60Kgs, calculate the maximum initial acceleration of the motorcycle?
#2
Given,
Motor peak torque, Tmax =120 N-m
At the starting conditions, the motor delivers maximum torque to the wheels
Gear ratio, G= 64/11 = 5.818
The torque at the rear wheel = Tmax*G= 120*=698.16 N-m
Distance of the wheel center from the ground = Rim radius + height of the tyre
= (17/2*2.54) + (160/10 * 0.6)
= 31.19 cm = 0.312 m
Torque = Force * Perpendicular Distance
Force = 698.16/.312
F= 2237.69 N
For maximum initial acceleration, assume full weight on the rear wheel i.e., 190+60 = 250kg
From newtons 1st law of motion, F=ma
ð a= 2237.69/250
ð a=8.95 m/s2
Hence the maximum initial acceleration approximately .912g.
Electric Bike Shops Near You
