I want to go (slightly) faster than 28 mph
Have a class 3 ebike which I am satisfied with. But I want to go faster on my commute. I average 20 mph, but occasionally I get tapped out at 28 mph, and am wondering what is available on the market at top speeds in excess of 28 mph so I can average higher than 20 mph. Truth be told, I would probably only average 10 minutes faster to work at higher speeds, but I want the option. The Lunar Apex seems to fit the bill. I don't like the Vintage motor cycle look. I currently have a Stromer. Thanks!
ElevenAD
biktrix Swift
Biktrix Ultra
Juiced Hyper Scorpion and Hyper Scrambler are also fast but i know you mentioned you dont like the Motorcycle look.
all 4 above bikes claim 35mph top speed
Timpo
Surface 604 Shred
Top Speed: 32mph
Juiced CrossCurrent X
Top Speed: 28mph but it has "R Mode" with 30+mph top speed
Surface 604 Shred
Top Speed: 32mph
Thanks!
FlatSix911
Have you considered increasing the max speed with eBike tuning… what type of motor do you have?
AHicks
When you start talking speeds like this, I would think part of a good plan might be asking yourself how far this bike needs to maintain that kind of speed. This is from a motor cooling standpoint, and battery amp hour standpoint.
For instance, most would want to avoid a bike that had smoke coming from the motor after a 35mph 3 mile sprint. As well, you would want to avoid a battery that was only able to maintain your target speed for 5 miles.....
Bottom line, there's way more too this than just a bike that's able to run in excess of 28 mph. That's much easier than you may know. You need to answer the questions for how long and how far too. That's the hard part.....
Ken M
Based on running simulations on Grin's website you can expect to run over 1200W (probably less on a Bafang Ultra Mid drive model ebike) to sustain a speed over 25mph/40kph but I do agree that for compelling urban mobility ebikes need the capability to enable riders to cruise at speeds around 28-32mph to be compelling as car supplement transportation solutions in the US.
I think a serious commuting ebike will come along with the right mix of mid or hub motor power and battery capacity.
Ravi Kempaiah
A 1000W DD hub motor would be able to do 30mph on long stretches.
Bafang Ultra on the Ultimate Commuter Pro is also very capable. I held 24.5 mph average including breaks over 12 hour period. The motor did not feel hot at all!!
If I exclude the breaks, I am sure the avg would be somewhere 27mph over 250 mile distance.
The duke
Here it is!
My bike is currently under warranty, but agree this would be an option to consider when the warranty runs off.
PaD
I would do some calculating before spending money on a faster bike. Are you sure you can shorten your commute by 10 minutes?
How long is your commute? Are there long sections where you can ride a bike over 28mph?
If your commute is e.g. 20 miles and you now average 20mph you would have to average 24mph to gain 10 minutes.
Maybe you commute is longer and then your ”new” average can be a little less than 24mph but it would still mean your top speed really has to go up. (depending on how many miles can be covered at top speed)
