Radrover Controller & Display Upgrade Kit
Sharkbait
This controller upgrade has started me on a path of near $1000 of upgrades and I couldn't be happier. Controller + motor first, then hydraulic brakes, and now a 52V 17.5Ah battery. Bought this one on AliExpress (took 12 days). I got the 40A one, because why not it's just a little bit more. Unit Pack power seems to get some recommendations on reddit & endless sphere. It's about 2.2 pounds heavier than my old 11.6Ah battery.
Installing the battery requires some soldering, had to cut the wire on the controller & solder in the new connectors. Anyway, performance was amazing. I hit 31 mph on throttle alone, that was after I went a few miles already, including one stretch in the park where I went 30 mph up a slight incline (while pedaling). I went a little over 31 a few times pedaling. I was spinning ok (years on road bikes) so I'm not sure I'll get a bigger chainring yet.
Anyway, here's how that battery fits on our frame:
I like your set up the fenders and rack and headlight....were those rad or sourced parts? Interested in prob getting a rad and doing mods as opposed to endless searching for perfect bike. Thx!
Sharkbait
My Radrover is a 2019 and the upgrade kit works great. Others have used the kit on their 2019 bikes as well.
how long and difficult was the upgrade process ? As in plug and play, modular replace etc or was there wire stripping and connection and mcgyvering involved? Looking at a rover and modding rather than risking a juiced rip and dont know any other that would meet specs at price point of rad after mods even. ?? Thots??
Sharkbait
Finally installed that 52V 17.5ah AliExpress battery onto the radrover. Holly hell does this thing fly now. The battery upgrade yielded a slight bump in torque and a faster top speed. It's easy to get up to 50 km an hour on flats cruising pedaling with PAS3/4.
@thatdude902 were you able to mount the battery using 3 mounting screws, I could only line it up and get the bottom two screws only. A little worried that this heavier battery is less secure on the frame, not sure what I can do to resolve this.
Dont know if i missed it, but did u simply change the battery or do the whole kit? Id love to get away with just a simple battery upgrade!!
Timpo
If you change the battery from 48V to 52V, yes you will be adding power and your speed controller will be fine since 48V and 52V are close enough.
Also, I changed my 48V battery to AliExpress 48V battery (I own Juiced, not Rad Power, just so you know)
Despite the same voltage, my new battery added noticeable power.
This is because my new battery cells had higher discharge rate.
For example, suppose there are two battery packs, both rated at "48V 14Ah"
But more expensive battery packs tend to have higher discharge rate. So for example, some battery might take 2 hours to discharge full 14Ah, whereas some sophisticated batteries might have capacity to drain all the electricity in 30 min. (These are just made-up examples)
Of course, there are other factors like BMS, speed controller and all that to determine the power.
Sharkbait
So are u saying the aliexpress battery uses better cells than the juiced or just the battery you had was degraded ?? I thot juiced used top5 battery suppliers....i totally understand the 52 vs 48 scenario i was just wondering if that was a one component fix for a little more power without the whole kit thing. What juiced do u have and what has ur experience been? They are on my list!!
Timpo
I have a Juiced CrossCurrent Air (with updated CCS speed controller), came with 10.4Ah 48V battery, and it was powered by Samsung.
Although I'm not certain, I think it was powered by Samsung 26F cells.
Now, I got an AliExpress battery, with Samsung 35E cells, 14Ah 48V and has much higher discharge rate.
The AliExpress seller was Eunorau, if you need to know.
My Juiced is not reliable, to be honest.
I don't mind it because I know fix the stuff by myself, also Juiced's price is good for the performance you get, so I can put up with it.
If you look at Juiced Forum on EBR, I think you'll find it pretty obvious that they need some help on customer support.
That said, some of the Juiced owners are happy, perhaps they improved their quality control?
Sharkbait
Yes this has been my struggle. The bikes with great specs have no support and the bikes with less than great specs have great support so prob better to go reliable in my case and upgrade at my leisure than try to buy high performance on start and have problems. I need reliability first and foremost. Being out a week or two with no parts and calls and emails is not ideal. Single parent two teenagers? Ha. I hardly have time to work. Lol. So i will go for either a rad or look for a lbs that has anything comparable that is realistic to work with. I think the rover will prob be the ticket.
Timpo
yeah I know what you mean, but as many people have posted on motorcycle forums all over internet,
Pick Two:
CHEAP
FAST
RELIABLE
thatdude902
Unfortunately the company that made those fenders is no longer in business. It was a company called "Big O." Rad made some bit later that looked very similar but they stopped making those (maybe too expensive? it was ~$159) and their current fenders aren't quite as full-looking. And the headlights were just some 12V light I got on Amazon and used a voltage regulator.
AHicks
Coming from the same kind of background you describe elsewhere, I can suggest that kinda like dirt and road bikes, watching what is available in the way of performance enhancements might help make your choice a bit easier.
AHicks
Pick Two:
CHEAP
FAST
RELIABLE
I just wanted to note that the stock '18 Rad battery is pretty capable of a sustained 1000w, and will support bursts in excess of 1300w - first hand experience using 35a KT controller and MAC 12t geared hub motor on a Rad City.
And I do agree one needs to select one of your 3 choices to start, but further, would suggest that with careful shopping, one CAN start CHEAP, then add money in sufficient quantities to satisfy ones need for speed. In my case, I would stack the resulting reliability up against anything available. This does assume average or better DIY'er abilities.
