fotografalex
Hi, have anyone replaced the easy motion battery to another battery that’s not easy motion ? Will it work?
Keep me updated, I will not change my battery in the near future. I had problem with the system shoot down, one off the cells in my battery pack had a bad connection.I just closed my bat. Pack ?.
Yea i’m not sure about that either. My original battery would not accept a Luna cycles charger due to the Bms(i had to disco/reconnect it ).
I guesa it also depends on what year the bike is.
Mine has limiter on throttle built in the controller or battery ?? I dont know yet...
We have to experiment ! I will work on my old bike in a few weeks and will do the same like you:
I’ll get a 48v 17amps or 21amps , drill the tube and allign the battery and hope that the controller accepts it. Is a 2015 model , the controller is cheap and very basic.
Or i may change tje controller too , this way it wiill work !! Then is all sort it out. Fast charger , big pack , i can even get a 1kw rear wheel instead of the 350watts...
Lmk how is your progress going.
I wish i knew that earlier. On my 2015 bike i had someone replaced them , but now i have better exp.It’s pretty easy to change the cells in a battery pack. You need a spot solder
The bikes from their prior years had the battery move a little bit left/right. Maybe that can be a cause but is unlikely.Did you progress on this issue?
I created a new thread around basically the same problem. The battery in my 2015 EVO is giving me headaches with intermittent faults (bike powers down) and measuring the output it shows the voltage goes down to 5V. Likely to be the BMS shutting down the whole battery after finding some problem (a flakey cell?). I asked in a couple of local businesses who rebuild batteries, and they say the Easy Motion batteries are "untouchable" for them (retrofitters) as the BMS needs reprogramming after any change. My only hope would be to refit a new battery and BMS within the EVO battery housing, but I may need to have some hope that this operation might be successful.
I am thinking a meaningful test would be to isolate all pins in the battery connector except the two big ones who transfer the power and see what happens.
Will post results...
My problem with the battery was that the bike stoped working sometimes. So I opened battery pack and there was one bad contact to one of the cells and I could solder it together. The bike have worked since then.Did you progress on this issue?
A few months ago I had Patrick from ebikemarketplace, he actually managed to replace all cells and have the bat. From 36v 11.6 to 14.5amps. So from a 416wh to 500wh. But it was not cheap - 500$... now I know some stuff, but I won’t go into changing cells b/c that’s really delicate work and I will leave it for exp. people or maybe until I am confident 1000%. It takes time too, I think it’s a 3-4hour job for a pro, maybe 7hours for a less exp. person.My problem with the battery was that the bike stoped working sometimes. So I opened battery pack and there was one bad contact to one of the cells and I could solder it together. The bike have worked since then.
I won’t pay 1000 dollar plus shipping and taxes for a new battery pack. If my battery starts to shut down again I will try to solve it my self. It would be great if I found a old easy motion battery pack and keep the connector and bms and just change the cells, the new cells don’t need to be in the battery pack. It will be a bit tricky to get the new cells to fit in the battery pack I think.
Another solution would be if it’s possible, just to get cheap battery and go behind the connector that’s attached to the bike and connect the new battery. But I don’t know if the system accept/recognizes a different batter.
Let me know how it works for you when isolate all the pins
I believe you, it’s going to take some time. It’s not much room in that battery pack. Did he change the bms too? I wish I had those extra ampsA few months ago I had Patrick from ebikemarketplace, he actually managed to replace all cells and have the bat. From 36v 11.6 to 14.5amps. So from a 416wh to 500wh. But it was not cheap - 500$... now I know some stuff, but I won’t go into changing cells b/c that’s really delicate work and I will leave it for exp. people or maybe until I am confident 1000%. It takes time too, I think it’s a 3-4hour job for a pro, maybe 7hours for a less exp. person.
With this there are no mistake allowed !!
They have in 2019 this model a 20mph max., the Xcross step with a720wh.-thanks to the 21700xell design. My 2015 one had. 418wh. What a difference ...almost2 batteries in one.In the UK I paid $800 each for 2 x 12aH batteries for our 2014 Neo Cross and City. The City bike battery was cutting out under load but the Cross is still good.
The new batteries contain an updated BMS that should better protect the cells from misuse, although I only found this out accidentally as it’s not documented. The City battery also represents an upgrade from the original 9aH. The only issue is that that the handlebar display now flashes empty every 10 seconds.
I can’t therefore be of help with the original question of how to avoid buying a battery from the manufacturer. And my costs and availability will be different in the UK. But I now anticipate another 5 seasons usage from the bikes. I considered changing the cells or having someone else do it but, compared to buying new units from the factory (originals from China, new ones Taiwan) I felt the risks and cost/benefits favoured the manufacturer. I do work on our bikes to keep them in good order but, for me/us the hobby is riding them. I also imagined that I might get the City battery re-celled as a spare but now see this as an unnecessary extra expense.
I asked a bike shop owner for help when my battery pack didn’t work. He told me that I should charge the battery for 24 hours so the cells got balanced.I have tested how it works by isolating the "signal" pins in the battery, so only connecting power contacts. Unfortunately it doesn't work.
The bike powers on, but the battery indicador blinks, the assistance indicator gets set to "No assist", and the controller does not allow to select any assistance level. Walk mode works, but only at 6Km/h. This seems to prove there is some handshake from BMS to controller, and there is no way to use a generic BMS (or a full "universal" battery).
Worst thing is that according to a comment in this videoSomeone say the battery stopped charging after the BMS got disconnected from power, so it seems to rule out the chance to "reset" the BMS only. The guy in the video in the following parts state the BMS does not work and shows the same behavior I have verified. Maybe some version may work differently.
What I have tested, and seemed to work fine is to do a full slow discharge (at home, using a light bulb) and then a charge using standard charger but out of the bike (if that has any difference). I returned from a 40Km route having lots of issues, did this procedure, and then a 45Km route without any single issue. Maybe the full (slow) discharge made a proper balancing?
Thanks for your suggestions.
