Talk me into/out of a Delite GX HS
smorgasbord
Looking for a full suspension bike that does it all - road trips up to 50 miles, plus some non-hardcore off road trails, 27.5" wheels, and some kind of rack to carry a few things like sandwiches, some tools, a jacket, etc. Not using the bike for commuting, so no heavy loads, no riding in rain (except by accident). Want the full suspension for handling when off road, and for comfort on road - but I'm not going to be a bold off roader. I've been told by others to just get a hardtail, but I find those don't handle as well on trails (but maybe that's because I haven't been on really good hardtails?).
I want the 28mph top limit, so I'm interested in one of the "HS" variants, which I think today are:
  • Delite GX rohloff HS
  • Delite GX extreme rohloff HS
  • Delite GX extreme touring HS
My concerns about the Delite:
1) Dealers are pretty far away from me. I'm in the SF Bay area, and my choices are Santa Cruz or SF proper. I'm about half way between them time-wise: 45 minutes each way. That wouldn't be so bad, except for the next concern:
2) R&M/Bosch are not friendly to DIYers. I maintain my own bikes today. Not just oiling and maintenance, but cable and chain replacements, brake upgrades, etc. I read in a thread here that R&M won't even give end customers the torque specifications for bolts? Really?
3) No throttle. I'm scared to even list this, because I know it triggers (pun intended) almost religious views. I don't ride the throttle - I use it to get going from a standstill and to get out of the occasional hairy traffic situation. If I get the electronic shifting Rohloff I probably won't need it for getting going since it'll auto-shift into a good gear for me when I stop. So, if all else was perfect I'd learn to live without a throttle.
4) The wait for the 2020 models is until November. The 2020 motors from Bosch seem to have performance/weight advantages over the current generation, and I'm in the minority that prefers the integrated look of the 2020 model. The 2020 Performance Line Speed gives both the 28 mph top speed with 75Nm of torque. So, while derestricting will be hard/impossible, I may not need to do that at all with the 2020 motors. (Details on the motors are here, click on the "Technical Details" button tab).
5) I test rode the GX rohloff HS (Gates carbon belt, Fox air fork upgrade). I was able to climb the 4th steepest hill in SF without an issue. I like the rohloff's wide gear range, but I didn't like the shifting. I don't shift under extreme chain tension anyway, but the automatic torque pausing was very disconcerting. Maybe I could learn to live with it, but at this point I don't see why I should pay for for disconcerting shifting.
6) Weight. What does the Delite weigh (without batteries)?
What other bikes should I be considering? I have looked at the Luna Apollo (I did get a brief test ride on an Apex), and have thought about the Biktrix Juggernaut Ulta FS, but the latter is pretty heavy at 75lbs with battery, and I'd have to settle for a seatpost rear rack. Then again, maybe the Delite is the same weight?
Thoughts, consideration, alternatives welcome. Heck, if you really think I should get a hardtail with a good suspension seatpost instead, I'll listen even though that's not my first choice.
David Berry
I like the Rohloff's wide gear range, but I didn't like the shifting. I don't shift under extreme chain tension anyway, but the automatic torque pausing was very disconcerting. Maybe I could learn to live with it.
I find changing down a gear whilst climbing a steep hill much easier on my derailleur-equipped ebike (Trek Powerfly 5 hardtail) than with Rohloff-equipped R&M Homage. With the derailleur there is simply no need to ease off the pedals; not so with the Rohloff. (Both ebikes have the same Bosch motor.)
If I need the really low #1 gear that the Rohloff provides, it is probably to get me out of a 'spot of bother' resulting from having to ease off the power to change down. If you anticipate a need to change down from gear #4 to #3, then up to #4, then down to #2 (and so on) choose a derailleur.
Rohloff can be more nuisance that it is worth… until one gets accustomed to it!
… David
I guess I would wait for the 2020 models, the new Delite especially looks very interesting with the new speed motor and integrated batteries.
Some of the torque specs will be printed on the individual parts. The rest you should be able to find by googling the part itself.
People seemed not to like the standard Rohloff shifter on ebikes, for some reason. Hard to figure out how to pause and shift, apparently. The new e-Rohloff works great though, you will get used to it for sure. Anyway, the standard shifter isn't an option on a R-M any more.
For a bike at this price point I would let the dealer do the service work, at least for a couple of years. By then you will know the bike inside and out.
webcurl
90 day standard warranty on the Luna Apollo with purchased upgrade options of up to 12 months, that would not inspire me.
R&M come standard with 2 years and free upgrade on frame for 5 years.
I have the SuperCharger, wish i spent the extra $ at the time for Delite but then they didn't have Gates/Rohloff at that time. The SuperCharger is great, just think the Delite would be even better.
I bought this knowing the dealer was an 8 hour drive away here in Oz, so for a 45 min drive, you're lucky :)
I have manual shift Rohloff and i'm completely fine with it!
I'd wait for new models if you can. Mainly because of resistance in pedaling beyond motor help.
What you read about R&M not giving Torque specs is probably from a particular person who had problems and didn't get the right help from his dealer so went to R&M direct and didn't get much help there either, possibly because of his tone? R&M most definitely prefer to deal with dealers only and i'm sure if the dealer asked for the Torque spec they'd get it.
Some of this stuff is beyond the capabilities of even the average bike mechanic working in a shop and some DIY'ers are not sensible, not saying you aren't.
If you want simple to fix, buy an old Toyota, if you want the latest best buy a Mercedes or similar but don't expect it to be simple to fix. It may last a long time before it needs fixing though, with appropriate maintenance.
Mr. Coffee
i don't know if the newest Delites use 203mm brake rotors or are still stuck on 180s, but if they are still using the 180s upgrade to 203s. These are extremely stout bikes and the 180mm rotors are inadequate on steep downhills.
Sirae
hello OP I may be wrong but the new version (according to the open space 2020) the (super) delight (mountain) don't have GX HS variation, there is the GT HS with rolhoff or without but not GX, the mountain version does not have HS variation, but you can take (which is my plan) a super delight GT rolhoff HS and for outdoor activity take the tires that exists on the mountain version (and eventually down the road upgrade the fork and the brakes) - and then you would have a GX HS kinda bike :D
tompat
There is a GX option that can be added.
GX option 140 mm travel, Fat Tire All-Terrain, dropper post, flat pedals, Ergon grips with bar ends, not in combination with ABS option, pannier rack 203,90 €
tompat
Lucky for you I still have the page in my web browser. LOL
Hope the copy n paste turns out well...
Riese & Müller 2020: catálogo y precios
Fabricante:
Hasta que subamos los modelos de bicicletas eléctricas Riese & Müller para la temporada 2020,puedes descargarte el catálogo provisional en este enlace:
Catálogo R&M 2020
Categoría: Bicicletas eléctricas.
Precios Riese & Müller 2020
Modelo / Motor / Batería / Display / Cambio / Precio
DELITE / SUPERDELITE
Superdelite
Superdelite GT touring New Performance CX, 1000 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 6.739 €
Superdelite GT touring HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 7.139 €
Superdelite GT vario New Performance CX, 1000 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 7.039 €
Superdelite GT vario HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 7.449 €
Superdelite GT rohloff New Performance CX, 1000 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 8.269 €
Superdelite GT rohloff HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 8.669 €
Superdelite mountain touring New Performance CX, 1000 Wh PowerTube, Intuvia, 11-speed, Fat Tire MTB, Fox 7.349 €
Superdelite mountain rohloff New Performance CX, 1000 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire MTB, Fox 8.979 €
Opciones
Kiox cockpit Kiox display with integrated adjustable stem 152,90 €
SmartphoneHub cockpit SmartphoneHub with integrated adjustable stem, not for ABS, rohloff and HS models 152,90 €
ABS (Europe only) Includes integrated cockpit, not for mountain and rohloff models, not in combination with Fox, SmartphoneHub, front carrier, GX option 509,90 €
RX Chip Hardware for Riese & Müller RX Connect 101,90 €
Fox air suspension Fork Fox Float 34 Performance Boost/rear shock Fox DPS, for GT models 100 mm travel, for GX option 140 mm travel, not in combination with ABS option 611,90 €
Pannier rack Allows attachment of light panniers, optional for all GT models, not in combination with GX option, can be selected at no extra cost 0 €
Front carrier With loading surface 101,90 €
Rear carrier For Superdelite mountain touring/mountain rohloff, standard equipment with all other models 203,90 €
Abus Bordo Alarm 6000A, 90 cm folding lock For Superdelite mountain touring/mountain rohloff, standard equipment with all other models 142,90 €
Delite
Delite GT touring New Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 5.719 €
Delite GT touring HS* New Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 6.119 €
Delite GT vario New Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 6.019 €
elite GT vario HS* New Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 6.429 €
Delite GT rohloff New Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 7.249 €
Delite GT rohloff HS* New Performance Speed, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 7.649 €
Delite mountain touring New Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire MTB, Fox 6.119 €
Delite mountain rohloff New Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire MTB, Fox 7.959 €
Opciones
Rear carrier With loading surface 101,90 €
Rear carrier For Delite mountain touring/mountain rohloff, standard equipment with all other models 203,90 €
Abus Bordo Alarm 6000A, 90 cm folding lock For Delite mountain touring/mountain rohloff, standard equipment with all other models 142,90 €
HOMAGE
Homage GT touring Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 5.099 €
Homage GT touring HS* Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 5.509 €
Homage GT vario Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road5.409 €
Homage GT vario HS* Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 5.819 €
Homage GT rohloff Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.629 €
Homage GT rohloff HS* Performance Speed, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 7.039 €
Opciones
Display Kiox 101,90 €
SmartphoneHub Not for ABS, rohloff and HS models 101,90 €
DualBattery (1000 Wh) Additional 500 Wh PowerPack 917,90 €
ABS (Europe only) Not for rohloff models, not in combination with SmartphoneHub 509,90 €
GX option Fat Tire All-Terrain, flat pedals, Ergon grips with bar ends 50,90 €
CULTURE GT
Culture GT touring Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 4.699 €
Culture GT vario Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 5.099 €
Opciones
SmartphoneHub 101,90 €
CULTURE
Culture city rücktritt Active Cruise, 500 Wh PowerPack Rack, Intuvia, Nexus 8-speed, coaster brake 4.289 €
Culture vario Performance Cruise, 500 Wh PowerPack Rack, Intuvia, Enviolo, belt 4.799 €
Culture automatic Performance Cruise, 500 Wh PowerPack Rack, Intuvia, Enviolo automatic, belt 5.099 €
SUPERCHARGER 2
Supercharger2 GT touring New Performance CX, 1000 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 5.719 €
Supercharger2 GT touring HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 6.119 €
Supercharger2 GT vario New Performance CX, 1000 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 6.019 €
Supercharger2 GT vario HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 6.429 €
Supercharger2 GT rohloff New Performance CX, 1000 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 7.349 €
Supercharger2 GT rohloff HS* New Performance Speed, 1000 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 7.759 €
Opciones
SmartphoneHub cockpit SmartphoneHub with integrated adjustable stem, not for rohloff and HS models 152,90 €
GX option Fat Tire All-Terrain, flat pedals, Ergon grips with bar ends, not in combination with heavy duty package 50,90 €
Heavy duty package 160 kg / 353 lbs, not for HS models, not in combination with GX option 50,90 €
CHARGER 3 / CHARGER 3 Mixte
Charger3 touring New Performance CX, 500 Wh PowerTube, Intuvia, 10-speed 4.289 €
Charger3 touring HS* New Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed 4.999 €
Charger3 vario New Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt 4.699 €
Charger3 vario HS* New Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt 5.309 €
Charger3 GT touring New Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 4.699 €
Charger3 GT touring HS* New Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 5.099 €
Charger3 GT vario New Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.999 €
Charger3 GT vario HS* New Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 5.409 €
Charger3 GT rohloff New Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.329 €
Charger3 GT rohloff HS* New Performance Speed, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.739 €
Opciones
GX option for GT models Fat Tire All-Terrain, flat pedals, Ergon grips with bar ends, not in combination with heavy duty package 50,90 €
Heavy duty package for GT models 160 kg / 353 lbs, not for HS models, not in combination with GX option 50,90 €
CHARGER 2 / CHARGER 2 Mixte
Charger2 city Active Plus, 500 Wh PowerTube, Intuvia, Nexus 8-speed 3.779 €
Charger2 touring Performance CX, 500 Wh PowerTube, Intuvia, 10-speed 3.879 €
Charger2 touring HS* Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed 4.589 €
Charger2 vario Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt 4.389 €
Charger2 vario HS* Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt 4.999 €
Charger2 silent New Performance, 500 Wh PowerTube, Intuvia, Enviolo, belt 4.289 €
Charger2 GT touring Performance CX, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 4.389 €
Charger2 GT touring HS* Performance Speed, 500 Wh PowerTube, Intuvia, 11-speed, Fat Tire Road 4.699 €
Charger2 GT vario Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.589 €
Charger2 GT vario HS* Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.999 €
Charger2 GT silent New Performance, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.489 €
Opciones
SmartphoneHub Not for HS models 101,90 €
DualBattery (1000 Wh) Additional 500 Wh PowerPack, not for Mixte 46 917,90 €
MULTICHARGER / MULTICHARGER Mixte
Multicharger GT light Performance CX, 500 Wh PowerTube, Purion, 10-speed, Fat Tire Road 4.079 €
Multicharger GT touring Performance CX, 500 Wh PowerTube, Purion, 11-speed, Fat Tire Road 4.489 €
Multicharger GT touring HS* Performance Speed, 500 Wh PowerTube, Purion, 11-speed, Fat Tire Road 4.899 €
Multicharger GT vario Performance CX, 500 Wh PowerTube, Purion, Enviolo, belt, Fat Tire Road 4.799 €
Multicharger GT vario HS* Performance Speed, 500 Wh PowerTube, Purion, Enviolo, belt, Fat Tire Road 5.209 €
Multicharger GT rohloff Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.119 €
Multicharger GT rohloff HS* Performance Speed, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.529 €
Opciones
SmartphoneHub Not for rohloff and HS models 101,90 €
DualBattery (1000 Wh) Additional 500 Wh PowerPack, not for Mixte 917,90 €
Passenger kit** Handlebar, footrests, padded shelf, not available for HS models 152,90 €
Wheel guard** Covers the rear wheel on both sides 61,90 €
Cargo bags** Large volume, 2 x 33 litres 163,90 €
Safety bar** Railsystem for child transportation 132,90 €
Side loader** Footrest, carries cargo boxes, pulls kids bikes 101,90 €
ROADSTER / ROADSTER Mixte
Roadster city New Performance, 500 Wh PowerPack, Purion, Nexus 8-speed, belt 3.469 €
Roadster urban New Performance, 500 Wh PowerPack, Intuvia, Alfine Di2 11-speed, belt 4.189 €
Roadster touring New Performance, 500 Wh PowerPack, Purion, 10-speed 3.369 €
Roadster touring HS* Performance Speed, 500 Wh PowerPack, Purion, 10-speed 3.879 €
Roadster GT urban New Performance, 500 Wh PowerPack, Intuvia, Alfine Di2 11-speed, belt, Fat Tire Road 4.289 €
Roadster GT touring New Performance, 500 Wh PowerPack, Purion, 10-speed, Fat Tire Road 3.469 €
Roadster GT touring HS* Performance Speed, 500 Wh PowerPack, Purion, 10-speed, Fat Tire Road 3.979 €
Opciones
SmartphoneHub Not for urban and HS models 101,90 €
Front carrier With loading surface, not for HS models 101,90 €
Rear carrier Optional for all models, standard equipment with touring HS and GT models 81,90 €
CRUISER / CRUISER Mixte
Cruiser city rücktritt Active Plus, 500 Wh PowerPack, Intuvia, Nexus 8-speed, coaster brake 3.269 €
Cruiser urban New Performance, 500 Wh PowerPack, Intuvia, Nexus 8-speed, belt 3.569 €
Cruiser vario New Performance, 500 Wh PowerPack, Intuvia, Enviolo 3.569 €
Cruiser vario urban New Performance, 500 Wh PowerPack, Intuvia, Enviolo, belt 3.779 €
Cruiser vario HS* Performance Speed, 500 Wh PowerPack, Intuvia, Enviolo 3.979 €
Opciones
Frame bag 50,90 €
NEVO GT
Nevo GT touring Performance CX, 500 Wh PowerTube, Intuvia, 10-speed, Fat Tire Road 3.979 €
Nevo GT touring HS* Performance Speed, 500 Wh PowerTube, Intuvia, 10-speed, Fat Tire Road 4.389 €
Nevo GT vario Performance CX, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.489 €
Nevo GT vario HS* Performance Speed, 500 Wh PowerTube, Intuvia, Enviolo, belt, Fat Tire Road 4.899 €
Nevo GT rohloff Performance CX, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 5.719 €
Nevo GT rohloff HS* Performance Speed, 500 Wh PowerTube, Intuvia, Rohloff E-14, belt, Fat Tire Road 6.119 €
Opciones
GX option Fat Tire All-Terrain, flat pedals, Ergon grips with bar ends, not for rohloff 26″ models, not in combination with heavy duty package 50,90 €
Heavy duty package 160 kg / 353 lbs, optional for GT vario and GT rohloff, not for HS models, not in combination with GX option 50,90 €
NEVO
Nevo city Performance Cruise, 500 Wh PowerPack, Intuvia, Nexus 8-speed 3.679 €
Nevo touring Performance CX, 500 Wh PowerPack, Intuvia, 10-speed 3.679 €
Nevo touring HS* Performance Speed, 500 Wh PowerPack, Intuvia, 10-speed 4.079 €
Nevo vario Performance CX, 500 Wh PowerPack, Intuvia, Enviolo, belt 4.189 €
Nevo vario HS* Performance Speed, 500 Wh PowerPack, Intuvia, Enviolo, belt 4.589 €
SWING 3
Swing3 urban New Performance, 500 Wh PowerPack Rack, Intuvia, Nexus 8-speed, belt 3.569 €
Swing3 urban rücktritt New Performance, 500 Wh PowerPack Rack, Intuvia, Nexus 8-speed, coaster brake, belt 3.679 €
Swing3 vario urban New Performance, 500 Wh PowerPack Rack, Intuvia, Enviolo, belt 3.779 €
Opciones
Front basket With lockable KlickFix adapter 81,90 €
Two baskets For rear carrier 101,90 €
SWING 2
Swing2 city Active Plus, 500 Wh PowerPack Rack, Purion, Nexus 8-speed 3.059 €
Swing2 city rücktritt Active Plus, 500 Wh PowerPack Rack, Intuvia, Nexus 8-speed, coaster brake 3.269 €
Swing2 vario Active Plus, 500 Wh PowerPack Rack, Intuvia, Enviolo 3.469 €
TINKER
Tinker vario Performance CX, 500 Wh PowerPack, Intuvia, Enviolo, belt 3.979 €
Tinker touring HS* Performance Speed, 500 Wh PowerPack, Intuvia, 10-speed 4.079 €
Opciones
Suspended seat post Cane Creek Thudbuster ST 152,90 €
Cargo platform for Tinker carrier Transforms the Tinker into a compact Cargo bike 71,90 €
LOAD 60
Load 60 touring New Performance CX, 500 Wh PowerPack, Intuvia, 11-speed 6.119 €
Load 60 touring HS* New Performance Speed, 500 Wh PowerPack, Intuvia, 11-speed 6.739 €
Load 60 vario New Performance CX, 500 Wh PowerPack, Intuvia, Enviolo, belt 6.429 €
Load 60 vario HS* New Performance Speed, 500 Wh PowerPack, Intuvia, Enviolo, belt 7.039 €
Load 60 rohloff New Performance CX, 500 Wh PowerPack, Intuvia, Rohloff E-14, belt 7.649 €
Load 60 rohloff HS* New Performance Speed, 500 Wh PowerPack, Intuvia, Rohloff E-14, belt 8.269 €
LOAD 75
Load 75 touring New Performance CX, 500 Wh PowerPack, Intuvia, 11-speed 6.329 €
Load 75 touring HS* New Performance Speed, 500 Wh PowerPack, Intuvia, 11-speed 6.939 €
Load 75 vario New Performance CX, 500 Wh PowerPack, Intuvia, Enviolo, belt 6.629 €
Load 75 vario HS* New Performance Speed, 500 Wh PowerPack, Intuvia, Enviolo, belt 7.249 €
Load 75 rohloff New Performance CX, 500 Wh PowerPack, Intuvia, Rohloff E-14, belt 7.859 €
Load 75 rohloff HS* New Performance Speed, 500 Wh PowerPack, Intuvia, Rohloff E-14, belt8.469 €
Opciones Load 60 / Load 75
GX option Fat Tire All-Terrain, flat pedals 50,90 €
Rear carrier Optional for all models, standard equipment with all HS models 132,90 €
Load 60 Low side walls, interior** Made of weather-resistant plastic, fitted inside 81,90 €
Load 60 Low side walls, interior** with child cover Made of weather-resistant plastic, fitted inside, child cover offers protection from rain or insects, fitted quickly 336,90 €
Load 60 High side walls** with tarpaulin Made of weather-resistant plastic, fitted inside, tarpaulin offers protection from rain 254,90 €
Load 60 High side walls** with lockable hard cover Made of weather-resistant plastic, fitted inside, lockable hard cover protects luggage 305,90 €
Load 60 High side walls** with child cover Made of weather-resistant plastic, fitted inside, child cover offers protection from rain or insects, fitted quickly 407,90 €
Load 60 Low sidewalls, outside Wooden, fitted outside, for commercial labelling, cannot be factory configured 91,90 €
Load 60 Two rear child seats, additional foot- Used in combination with side walls, belts for two children well, additional luggage compartment, splash guard 254,90 €
Load 60 Additional footwell, additional luggage compartment, splash guard** (without child seats) Used in combination with side walls 50,90 €
Load 75 Low side walls, interior** Made of weather-resistant plastic, fitted inside 81,90 €
Load 75 Low side walls, interior** with child cover Made of weather-resistant plastic, fitted inside, child cover offers protection from rain or insects, fitted quickly 611,90 €
Load 75 High side walls** with tarpaulin Made of weather-resistant plastic, fitted inside, tarpaulin offers protection from rain 254,90 €
Load 75 High side walls** with lockable hard cover Made of weather-resistant plastic, fitted inside, lockable hard cover protects luggage 305,90 €
Load 75 Two rear child seats** Used in combination with side walls, belts for two children 203,90 €
Load 75 Two rear child seats with additional single front child seat and footwell** Used in combination with side walls, two rear child seats, belts for 3rd child and larger footwell for children, not in combination with tarpaulin 560,90 €
Load 75 Two rear child seats with additional single front child seat, footwell and luggage shelf** Used in combination with side walls, two rear child seats, belts for 3rd child seat, space to store bags or drinks crates, not in combination with tarpaulin 662,90 €
Additional chain lock 130 cm, including chain bag Complements the standard frame lock50,90 €
PACKSTER 40
Packster 40 touring Performance CX, 500 Wh PowerPack, Purion, 10-speed 4.489 €
Packster 40 touring HS* Performance Speed, 500 Wh PowerPack, Purion, 10-speed 5.099 €
Packster 40 vario Performance CX, 500 Wh PowerPack, Purion, Enviolo, belt 5.099 €
Packster 40 vario HS* Performance Speed, 500 Wh PowerPack, Purion, Enviolo, belt 5.719 €
PACKSTER 60
Packster 60 touring Performance CX, 500 Wh PowerPack, Purion, 10-speed 4.799 €
Packster 60 touring HS* Performance Speed, 500 Wh PowerPack, Purion, 10-speed 5.409 €
Packster 60 vario Performance CX, 500 Wh PowerPack, Purion, Enviolo, belt 5.309 €
Packster 60 vario HS* Performance Speed, 500 Wh PowerPack, Purion, Enviolo, belt 5.919 €
PACSKSER 80
Packster 80 touring Performance CX, 500 Wh PowerPack, Purion, 10-speed 4.899 €
Packster 80 touring HS* Performance Speed, 500 Wh PowerPack, Purion, 10-speed 5.509 €
Packster 80 vario Performance CX, 500 Wh PowerPack, Purion, Enviolo, belt 5.409 €
Packster 80 vario HS* Performance Speed, 500 Wh PowerPack, Purion, Enviolo, belt 6.019 €
Opciones Packster 40 / Packster 60 / Packster 80
DualBattery (1000 Wh) Additional 500 Wh PowerPack, in combination with Box or Carry System 917,90 €
Comfort kit Includes comfort handlebar and wide saddle, not for HS models, can be selected at no extra cost – €
Packster 40 Box** Wooden box, folding or removable side walls 152,90 €
Packster 40 Box with tarpaulin** Wooden box, folding or removable side walls, tarpaulin offers protection from rain 244,90 €
Packster 40 Carry System** Frame with padded Cordura side walls 203,90 €
Packster 40 Carry System with tarpaulin** Frame with padded Cordura side walls, tarpaulin offers protection from rain 295,90 €
Packster 40 Carry System with child cover** Frame with padded Cordura side walls, child cover offers protection from rain or insects, fitted quickly 407,90 €
Packster 40 Glove compartment, lockable** For use with Box or Carry System, cannot be combined with child seat 91,90 €
Packster 40 Single child seat** For use with Carry System, belts for one child 152,90 €
Packster 60/80 Boards** Narrow boards made of weather-resistant plastic for front, bottom and rear 101,90 €
Packster 60/80 Box** Made of weather-resistant plastic, removable side walls 254,90 €
Packster 60/80 Box with tarpaulin** Made of weather-resistant plastic, removable side walls, tarpaulin offers protection from rain 356,90 €
Packster 60/80 Box with child cover** Made of weather-resistant plastic, removable side walls, child cover offers protection from rain or insects, fitted quickly 611,90 €
Packster 60/80 Two rear child seats** For use with Box, belts for two children 203,90 €
Additional chain lock 130 cm, including chain bag Complements the standard frame lock 50,90 €
BIRDY
Birdy city Nexus 8-speed 2.449 €
Birdy touring 10-speed 2.349 €
Birdy rohloff Rohloff 14-speed 3.779 €
Opciones
Sport or Comfort stem, adjustable height Can be selected at no extra cost – €
Carrier Suitable for use with panniers 101,90 €
Lowrider Includes inline rollers for the carrier, Birdy can be pulled on the lowrider 71,90 €
Pannier adapter for handlebar Includes KlickFix handlebar adapter, lockable, cannot be factory configured 50,90 €
Supernova lighting with hub dynamo For Birdy touring, standard equipment with all other models 203,90 €
Abus Bordo, 90 cm folding lock Perfect for use with Birdy thanks to the longer Velcro straps 91,90 €
Air pump Fits into the seatpost 40,90 €
MKS Ezy Promenade detachable pedals Quickly and easily removed, cannot be factory configured 81,90 €
Frame bag Fits under the top tube, cannot be factory configured 40,90 €
Carry bag For carrying the folded Birdy, fits onto the top tube after use 40,90 €
Rear elastomer yellow/green Yellow = soft, Green = harder, cannot be factory configured 15,90 €
Front shock absorber, harder Harder fork elastomer, cannot be factory configured 15,90 €
Sirae
The only thing that bothers me is that there is no mention of the possibility to put in the powertube 625 that were just announced, according to what you show it is 1000w only which is a shame cause 250W extra will for sure be in next year model
webcurl
Fabricante:
Catálogo R&M 2020
Superdelite
Opciones
Delite
Opciones
HOMAGE
Opciones
CULTURE GT
Opciones
CULTURE
SUPERCHARGER 2
Opciones
Opciones
Opciones
Opciones
Opciones
Opciones
Frame bag 50,90 €
NEVO GT
Opciones
NEVO
SWING 3
Opciones
SWING 2
TINKER
Opciones
LOAD 60
LOAD 75
PACKSTER 40
PACKSTER 60
PACSKSER 80
BIRDY
Opciones
Damn it, i don't want to read it! :)
Looks like they have my dream bike now (after purchasing a 2018 SuperCharger in 2018):
SuperDelite Mountain Rohloff, Belt, Fat Tire, Fox with GX option + front & rear carrier.
Wonder why no SmartPhoneHub for Rohloff and what the RX chip for RX connect is.
Also wonder what rims and tire widths can go on.
But i have to stop wondering :)
tompat
You can always long for more..
I have the Supercharger with dual batteries (1000 Wh) and it does my 2 hour daily commute (64 km total / average 35-38 kmph) with good margin.
tompat
Yeah... lol.. same here although I am longing for the Load 75 Rohloff HS, my Supercharger is totally awesome but now and then I'd like to carry more stuff than I can with pannier bags.. so enter the idea to commute with the cruise ship called Load 75.
It's a GPS tracking service although it's only available in a very few countries, maybe Germany only. It's a complete package with GPS tracking, phone app and insurance (!!), if I recall correct you get a new bike if it gets stolen irrecoverably. So it's more than a piece of hardware, it's a service and thus needs to be negotiated with insurance companies and mobile data carriers in the countries it would need to be enabled in.
Sirae
Hopefully the model i will take !! :D :D (just not sure with the front carriere cause it may be like the supercharger which means moving when you turn which I am not sure about
Also GX option what does it bring concretly ? better fork and breaks ? is it really worth it ?
I was almost buying a supercharger last month !! good i didn't !
