Tool for adjusting that rear brake pad on an iZip Dash
Cameron Newland
That looks really cool!
Would using this tool make it so that you don't have to adjust the brake cable tension every ~100 miles when you wear down the brake pads a bit and consequently lose some braking power, or is this a tool that you would have to use in conjunction with sporadic brake cable adjustments? Just curious, and I apologize in advance for my lack of technical sophistication re: disc brakes! ;-)
Paul E.
It doesn't reduce the need for adjusting, it just makes the job quite a bit easier if the adjustment screw is not accessible with any normal tools without dismantling anything.
