Tubeless ST2?
KIOMON
So I got my first flat in years on my new ST2, and I was thinking of going tubeless. Has anyone else done it? If so any tips? I was going to go the Stan’s route, and use the DT Swiss Tubeless rim tape. Any issues or problems going tubeless?
Chuck E. Cheese
I’ve thought about doing the same. Right now I have Schwalbe Marathon GT365 tires, Mr. Tuffy Brown tire liners, and slime pre-filled tubes. That’s a lot of weight and even though it protects fabulously from punctures I keep waiting for the inevitable pinch flat. I keep my tires inflated higher than I would like just to minimize movement of the tire liners and tubes.
So long answer to your short question: Nope. Haven’t done it yet. If you do go that route please report back with your experience.
Marci jo
Same here. Have some 1.80 inch slightly knobby tires. Thinking of converting to tubeless but looking for more info. Will be watching this thread.
KIOMON
Sooo did the full set up, rewrapped the rims with tubeless tape (DT Swiss) and changed the valve stems, mounted tire back on and I couldn’t get it to seat. I used an air compressor (don’t even attempt with a pump). The culprit, I think, is the fit of the tire. The stock tires just aren’t that tight on the rim, and even with using a compressor, there isn’t enough air volume to overcome the spacing.
This tire isn’t listed as tubeless ready, so it’s not a huge surprise. I did leave the tubeless rim tape installed, and I put back the stock rim liner to protect the tube. I patched my old tube (pin hole), and put it all back together, and put 30 miles on the bike no problem.
I think I am going to go the foam tire liner route (tannus) on the back wheel for protection. And then when this tire runs out, switch to something that’s tubeless ready and try again. I really really never want to have to change that rear tire on the road.
Rincon
After years with my ST2 and no flats—in fact I have two ST2 bikes—one finally flatted after transporting it from California to Sedona, AZ. No idea why it had a front flat upon arrival. But after years of goat heads, pot holes, back roads and rutted dirt roads I see no need for tubeless. The Marathon tires and slime tubes do the job.
I do run tubeless with Orange Seal on my Salsa Warroad gravel bike, non-electric. The tires are thinner and I can run them at lower pressure to soak up the ruts. I ride the same roads with my ST2, but that has shocks.
diabloo71
Just a note on getting the tire to seat on a tubeless setup with a compressor.... make sure you remove the core from the valve stem. this allows much more air to be pushed into the tire at once.
good luck.
