Voltbike Enduro Rear Suspension
#1
My enduro came with an A5-RE suspension. I only see a single adjustment valve. The suspension is either super stiff (i.e. no sag) or has no rebound. Is it possible I have a bad shock? What PSI do you run?
#3
I run 175 PSI and works well. It is very sensitive to pressure a few lbs either way makes a huge difference. Try making smaller adjustments around the 175 PSI area. A little trial and error will find your number.
Feliz
If you're still around how much do you weigh? Thanks.
