2020 Homage Shock Specifications
NVBrian
It appears that my 2020 homage is in need to a shock replacement. I searched around and I'll I can find is that it is a "X-Fusion O2 Pro Air, 100mm Travel." Does anyone know the length specifications? I am considering either replacing it or swapping it out with a different brand. Thanks.
Walter van Dusen
Lexington
Walter van Dusen
Lexington
You're the man. Thanks!
You might need to get a new inlet insert as the one I took out of the stock shock was a smidgen too small. It needs to be press fitted in. I’ll update once the new parts come in and after I install mine. I did test the switch remote and that worked perfectly. I rewatched the YouTube video very closely a few times.
