Bbs02 500w 48v max amps
k_oflynn2000
Hello, i have a bbs02 500w 48v and have just purchased the cable to fiddle with the settings as i want to allow throttle in pas 0. Ive been told that the 500w 48v is just the 750w motor with the amps limited to 18. So am i correct in asuming that if i set the amps to 25 on the setting i will instantly have a 750w motor???? My battery can handle 25amps but i was thinking of maybe just increasing it to 21 or 22 to avoid to over heating problems. Has anyone done this with the 500w????
rick-n-ns
I'm no expert on this stuff, but as no one else has replied I will. I believe the 500 watts is "nominal" and at your max draw (heavy load) of 18 amps X 48 V your already over 750 watts, 864 to be precise.
Waiting to get my BBS02 shortly, have to ask do you feel you don't have enough power ?
k_oflynn2000
Hi there, yes im really happy with the power, i was advised to get the 500w 48v because it runs cooler and has less chance of frying the controler seems its basically just a detuned 750w. This is why i wonder if i can just up the amps a little bit. More power is always good I mainly use mine to walk the dog on forest tracks and with 36 teeth on the back and a 42t lekkie bling ring there really isnt a hill i cant climb, traction becomes an issue way before the motor struggles. Especially if your giving it some leg power to. I imagine that the 750 with 7 more amps is really impressive but then you are risking the problems a lot of people talk about but i think as long as you maintain high rpm the motor is ok. Going up hils i always aim to pedal as fast as possible and you can just feel that the motor prefers this.
rick-n-ns
I think you answered your own question..."but then you are risking the problems" If your happy with the power as is I wouldn't go boosting anything. The battery will last longer, and so will all the electrical parts.
Don't know which model bike you have, but I don't recall a BBS02 @ 48V that was not rated at 750 Watts ? As I mentioned no expert here, but I sure have read a lot. So which model bike do you have ?
k_oflynn2000
The 500w bbs02 comes in 36v or 48v the 48v is the detuned 750 just running at 18amps instead of 25amps. This is why it doesnt get as hot. I have mounted the kit on a 2011 mondraker dune full suspension which took me ages to find. It has a 73mm bottom bracket and just enough space to squeeze in the battery. I tried to upload a pic but it says "file to large"
k_oflynn2000
