Bypassing the speed Limiter on a CrossCurrent S2
wings02
Has anyone been able to figure out how to bypass the speed limiter on a new Juiced CrossCurrent S2 ebike. I just received mine last week. The bike rides great.
I'm especially impressed with the torque sensor. My only complaint is the top speed with throttle only is just over 18mph. I can't get up to the maximum allowable speed of 20 mph. Any input would be appreciated.
Timpo
I don't think you can, that's why Juiced sells offroad controller.
Timpo
Unless you want to switch to Eunorau controller?
I don't know who else sells Bafang controller.
Timpo
Is there enough space to fit KT controller?
KT controller is more popular / common.
linklemming
Have you changed the overall speed limit yet? My CCX came set to 20mph and I had to change it to go 28mph. This for PAS only
See video on how to use LCD setup
You can also add race mode but it only adds a few mph as your power limited above 28mph anyway. The best I ever saw was 31mph and I was pedaling hard on a slight downhill
That being said, the throttle is always limited to 20mph (not sure if race mode allows throttle above 20mph but I doubt it)
wings02
I did increase the speed limit to 40 and also added Race mode. Those settings are only for pedal assist.
wings02
Has anyone experimented by changing the wheel diameter on the settings menu? I do understand that will affect the accuracy of the speedometer
