Cost-Benefit Comparison: High Speed Suspension for Electric Bikes ("CA Motorized Cycle")
Mike leroy
What suspension is necessary for a "California motorized cycle" or "eMotorBike" capable of 45+ mph? An eMotorBike must be less than 3720 watts, according to U.S. DOT regulation. This article uses the HPC 78 volt, 3500 watt motor as a reference point. The battery tank holds two 13Ah NMC chemistry batteries. I choose the HPC Revolution based on NMC battery chemistry. Also, the tank accommodates a 26Ah battery with a 100 mile range at 20mph.
The various HPC Revoution electric bike suspensions are compared. My personal aim is explained in the post entitled "Take Control of Fast Lane When 'Bike Share' Lane is too Dangerous for Electric Bikes". Please note the HPC utilizes a swingarm, rather than a bicycle triangle. The rear axle maintains a level position with the bicycle bottom bracket (pedal axle) because shock absorber allows the frame to flex. A swingarm is more roadworthy than a traditional mountain bike rear shock system because the tire maintains better traction.
After writing this article, the traditional diamond frame/mountain bike suspension no longer makes sense to me for electric bikes. Some people may dislike the motorcycle style. For the higher speeds electric bikes enable, a swingarm suspension makes overwhelming sense. I feel foolish for not realizing how important frame design is to achieve the best full suspension. I was blinded by the features of the shocks, rather than functioning of the entire suspension system.
I choose a downhill bike because I plan to register the eMotorBike as a legal CA motorcycle. The downhill coasting speed on my 10% grade hill is over 45mph. I feel a downhill frame and suspension best suits the conditions of my road. The uphill speed limit is 35mph. I plan to only use the fast, or left-hand lane to avoid the dangers of the right-hand bike share lane. The fast lane safety strategy is used almost exclusively by motorcycles and scooters on my hill. The sanity of my bike share lane is dubious, at best.
The suspension must handle the 15 and 25mph speed bumps.
The HPC Revolution bikes are based on a modular "platform" 19 pound frame. Components can be configured to match your needs. The bike weighs less than 80 pounds fully configured with the 3500 watt motor. I also plan to buy a wheel without a motor and a 1000 watt rear hub motor, because the frame only weighs 19 pounds. Simply swap wheels for different purposes.
I plan to commute on the train with the bike. I plan to upgrade the suspension and gearing on the HPC Revolution Sport (i.e., base model). This article explains my education and reasoning process.
I write articles in installments from the comfort of my bed and iPad. I research the information before starting the article. Over the course of a week, my research becomes more extensive. I update the first post as I learn. Please check the "Last Edited" date in the bottom right hand corner of this post to know if additional content was added.
The articles are written with an iPhone app for Cost-Benefit analysis. The ten basic aspects are considered in a methodical manner. The previous paragraphs explained the "Purpose". The aspects are listed below. The Cost-Benefit approach is a useful process to resolve most difficult problems in life, including political, social, emotional or business.
  1. Purpose
  2. Cost
  3. Risk
  4. Bias
  5. Benefits
    • Ease
    • Economy
    • Enjoyment
    • Elegance
    • Endurance
    • Excitement
The Cost-Benefit diagram is shown below. So far, the only known information is an expensive eMotorBike with a clearly defined Purpose. The aspects are rated on a scale from 1 to 5. The unknown information is rated as a "3" or average, because nothing is known. We assume the components are average. As we gain more information, we update the picture. The Cost and Purpose is rated as a "5".
Revolution 5.0-
Top Speed: 50+MPH
RockShox Boxxer front fork 203mm travel
RockShox RC2 rear shock- 8+" of frame travel
Schlumpf High Speed Drive (2.5X) Allows high speed pedaling past 50 MPH!
SRAM X9 Rear Derailluer/Shifter, 18 Speeds total
Revolution X 5.0-
Top Speed: 50+MPH
RockShox Boxxer World Cup Keronite front fork 203mm travel
RockShox VIVID RC2 rear air shock- 8+" of frame travel
SRAM X0 Rear Derailluer/Shifter, 20 Speeds total
The primary differences between the two suspension systems seem to be cost and weight. The amount of travel is the same. Unclear about durability, structural strength and handling characteristics.
"As with all shock absorbers it usually consists of two parts: a spring, and a damper. The spring may be implemented with a steel or titanium coil, compressed air, or even an elastomer. Different spring materials have different spring rates which have a fundamental effect on the characteristics of the fork as a whole. Coil sprung forks keep an approximately constant spring rate throughout their travel and act linear. The spring rate of air sprung forks however increases with travel, making them progressive. Titanium coils are much lighter but also come at a significantly increased cost. Air sprung forks are generally lighter still.
Air springs work by using the characteristic of compressed air to resist further compression. As the spring itself is provided by the compressed air rather than a coil of metal it is much lighter; this makes their use popular in cross country designs. Another advantage of this type of fork design is that the spring rate can easily be adjusted by changing the air pressure within the fork. This allows a fork to be effectively tuned to a rider's weight. To achieve this in a coil sprung fork one would have to swap out different coils with different spring rates. However air pressure naturally controls both spring rate and preload at the same time, requiring air forks to have additional systems to adjust preload separately, adding to its complexity. Another disadvantage of air sprung forks is the difficulty in achieving a linear spring rate throughout the fork's action. As the fork compresses, the air held inside is compressed. Towards the end of the fork's travel, further compression of the fork requires ever greater force. This results in an increase in spring rate and gives the fork its progressive feel. Increasing the volume of the air inside the spring reduces this effect but the volume of the spring is ultimately limited by the need to be contained within the fork. The use of two air chambers within the system has allowed a more linear feel to air suspension, this is achieved by having a 'reserve' chamber that becomes connected to the main chamber when it reaches a certain amount of compression. Once achieved, a valve opens and effectively makes the chamber larger. By linking the two, the force needed to compress the air in the chambers is reduced which reduces the exponential spring rate feel traditionally associated with air systems when approaching the end of the suspension's travel."
Mike leroy
I would get the bike with the correct electronics for you, and eventually stitch out the shocks with fox
OK. First, I want to establish the initial costs. Second, compare Fox cost with the HPC Revolution shocks. The additional cost has to be weighed against the benefit.
I plan to use the 78V, 3500 watt motor found on the Revolution Sport. Chris, at HPC, told me I can customize the bike to my needs. I will mix and match the components for the Revo Sport that best suits my needs.
Racingkyle
Fox has always been miles ahead, so you will get much better performance. The fox shocks are more expensive, but they will serve you much longer
Mike leroy
OK. My approach is establish a basis for comparison with the stock bike. After the stock shock features are explained, then we can compare with Fox.
Mike leroy
I think that the sport has spring shocks in the front, not sure though.
Kyle,
I plan to buy the HPC REvolution Sport as the base model. My initial approach is to upgrade the suspension to either the HPC Revolution X5 or HPC Revolution 5. The purpose of this post is to teach myself the differences. I want to find the most cost effective solution to handle 45mph speeds.
Racingkyle
True, it is really preference on which shocks you buy. The fox will probably be slightly more responsive and last longer. The rock shox will be less responsive and not last as long. Some fox shocks have remotes to wirelessly control the sensitivity. The suspension from the 5 is nice, and the suspension from the x5 is very nice. It depends on your uses which suspension you need. Can you state your needs?
Mike leroy
Shocks should perform like a motorcycle at 45mph, rather than a bicycle. The suspension must handle 15 and 25 mph speed bumps. Ordinary road potholes must also be safely absorbed.
Racingkyle
Dot standards limit to 3700 watts, so the revolution sport isn't a motorcycle. I understand where you are coming from, but remember, the Stromer won't work for everyone. A low power electric bike will not work for people in a very hilly area. Here in California, we need power to climb the hills without pushing a bike. We need a strong bike to take us through the off-road trails when we want to take a short cut or have fun. There is a very good purpose to this type of bike to us.
Racingkyle
Exactly, but you need a sensitive shock to allow this Spingarm to absorb small shocks.
So, it seems to me a swingarm provides more traction and shock absorption, than a traditional bicycle diamond frame rear suspension. The swingarm is independent from the frame.
Mike leroy
The spec sheet has the following info. Is this sensitive enough?
Counter Measure™
Engineered For The Elite, the new Vivid conquers several once-thought-impossible engineering feats. Technologies like Counter Measure, which reduces the breakaway force of the shock to virtually zero pounds, transforming small bumps in to traction-generating performance.
Read More
Rapid Recovery™
Who doesn't want more available wheel travel for successive hits? The Rapid Recovery System allows the shock to recovery faster between consecutive bumps, letting the wheel track the ground with greater precision. This more active suspension system, doesn’t pack up and enables the bike to ride in a higher and softer part of the spring rate. Rapid Recovery gives the rider access to more available wheel travel, bump after bump, to achieve a smoother and more controlled ride.
Read More
Dual Flow Adjust™
DFA’s kind of like Glam Metal. Two things you’d never think could go together, but somehow work like magic. Let’s say you’re riding a course with both monster drops and lots of braking bumps. Convention says you have to adjust your fork to handle one or the other. RockShox DFA says no, use its dual independent damping circuits to tune it to handle both. Absorbing the big hits while staying plush through the small stuff, like makeup and metal.
Read More
DAMPING External beginning stroke rebound, ending stroke rebound, low speed compression
CONFIGURATIONS 200x57, 216x63, 222x70, 240x76
SPRING Twin Tube Solo Air
SPRING ADJUST Air pressure via single Schrader valve
Racingkyle
Counter Measure™
Read More
Rapid Recovery™
Read More
Dual Flow Adjust™
Read More
It seems to be all marketing. The best thing to do is get the sport and see how you like the shocks. If you don't like them look for a fox alternative. I wouldn't get the 5.0 just because of the suspension because that's just too much. You could try to twist their arm for a suspension upgrade, but I wouldn't count on it.
Mike leroy
Which Fox shocks would you get? I assume Fox comes in the same size? I could simply ask for Fox because the frame is modular. Just like buying a frame from any other bike manufacturer.
I assume the frame attachment hole is the same diameter for Fox and Rock Shox?
The most important aspect is the swingarm. The frame only weighs 19 pounds. I do not want a traditional diamond frame with a full suspension.
