Creo Rattle
RobertOK
Do any of you Creo owners experience any rattling on your bike that would be unusual on an analog bike? It sounds like there is some play in the gears in the motor. It makes no difference if the motor is on or off or if I’m pedaling or not. I own a Levo SL and other than the whirring motor sounds it makes no more noise than an analog bike. The rattle isn’t that loud, but annoying and I’m wondering if my expectations are too high?
My SWorks Creo will soon be out of its one year warranty (I think only the motor has an extended warranty). The bike has produced this sound since day one. It often occurs on rough pavement but not exclusively. Sometimes happens even when pushing the bike. It’s been to the dealer several times and had the frame, crank and cables checked to no avail. For the latest effort Specialized replaced the motor again to no avail.
(I saw the earlier thread about the splitter cable rattling, I don't think that's it)
RobertOK
Thanks I didn't try that, one was loose. Will ride the bike later today and see if it helps, but am skeptical because the sound is a different cadence than the rotating wheel.
RobertOK
So I just looked it up and looks like most of their stuff does have a 2 year warranty. That's good news, I wonder if rattles are covered and if that may be a local dealer problem/solution?
kahn
northWET washington
Have you tried putting it up on a rack and tapped around various areas of the frame and crank area? Finding a rattle while riding is not easy as it can sound like it is emanating from almost anywhere. Good luck
RobertOK
I just went on a short ride trying John.JCAT's suggestion. The tube stem lock wasn't it, but I'm beginning to believe it is the Future Shock. Will have to do some more tests as it's not consistent. At this point it's kind of halfway between a rattle and a click. The pre-engine change was more of a rattle.
DJRib
Columbus OH
Bike rattles can be notoriously difficult to diagnose. Good Luck.
Also I thought they had a 2-year warranty on everything but the frame carried a limited lifetime warranty to the original owner (only)
abercrombie
Sorry, but this may not help much. I had some weird rattling for several months on my Creo Comp SL that sounded like it came from the mid-drive motor. It would rattle near the motor area every time I went over any road imperfections or bumps making it very annoying to ride. Was more pronounced in the lower gears and less noticable in high gear if that helps. Really decreased my enjoyment of the bike knowing I paid $7k for something that sounds like a broken Fisher-Price toy.
Fast forward to last month, I finally brought it into a 3rd party shop (not the dealer) to replace a bent derailleur hanger that happened more recently. I like this 3rd party shop because the mechanic is fast, cheap, and very personable. After the minor fix, the noise went away. Never followed-up as to what exactly was done for the noise to disappear.
RobertOK
Too bad you never figured it out. If you ever find out please let us know. Thanks for the info.
