Cyrusher XF650 Review
Hey guys! Our review of the XF650 will be premiering shortly! Hope you enjoy :)
Cyrusher Official Website - https://www.cyrusher.com/en/bikes/XF650
MAKE:
Cyrusher
MODEL:
XF650
PRICE:
$1,800
BODY POSITION:
Upright, Forward
SUGGESTED USE:
Neighborhood, Urban, Commuting, Trails, Some Off-Road
ELECTRIC BIKE CLASS:
Class 3
WARRANTY:
1 Year Comprehensive
AVAILABILITY:
Canada, United States, Europe, Worldwide
MODEL YEAR:
2021
BIKE WEIGHT:
60.72lbs
BATTERY WEIGHT:
7.78lbs
MOTOR BRAND:
Lankeleisi
MOTOR TYPE:
Rear-Hub, Geared
MOTOR NOMINAL OUTPUT:
750 watts
MOTOR TORQUE:
80 Newton meters
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
13 ah
BATTERY WATT HOURS:
624 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
5 hours
ESTIMATED MIN RANGE:
22 miles
ESTIMATED MAX RANGE:
50 miles
DISPLAY TYPE:
S700 Advanced 3.7" LCD
READOUTS:
Charge indicator, Speedometer, Odometer, Trip Odometer, PAS Level, Errors
DRIVE MODE:
Pedal Assist, Throttle, Walk Mode
TOP SPEED:
26 mph
FRAME MATERIAL:
6061 Aluminum Alloy
GEOMETRY MEASUREMENTS:
20" Reach, 33. 5" Stand Over Height, 20" Minimum Saddle Height, 27" Maximum Saddle Height, 28.5" Width, 49" Wheel Base, 75" Length
FRAME COLORS:
Red, Blue, Yellow
FRAME FORK DETAILS:
Coil suspension & hydraulic lockout and preload adjustment; 80 mm travel; 35 mm deformation
ATTACHMENT POINTS:
Fender Bosses, Rear Rack Bosses
GEARING DETAILS:
7 Speed 1x7 Shimano
SHIFTER DETAILS:
Shimano SIS Index (Right Side)
CRANKS:
Lankeleisi 160mm
PEDALS:
Metallic With Reflectors
BRAKE DETAILS:
Zoom Mechanical Brake Levers with Motor Cutoff, XTech Brake Calipers, 160mm disc brakes
GRIPS:
Rubber Non-Locking
SADDLE:
Lankeleisi Sport
TIRE BRAND:
Chao Yang 26” x 4”
TIRE DETAILS:
Max Air Pressure is 20 PSI
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Fenders Included, Kickstand, Rear Rack, Assembly Tools
OTHER:
Locking Removable Battery Pack, 2 Amp Standard Charger, Max Total Weight 330lbs, 250-lumens front light
cyrusher ebike electric bike review fat tire mtb emtb mountain bike hardtail 48 volt max distance performance
