Ennovation
- USA
Hey guys! Today we're looking at the Cyrusher XF690. This is a monster of a bike that has a lot of power, sleek looks, and folding capabilities. Check the description below for all the specs.
Cyrusher Official Website - https://www.cyrusher.com/products/xf690-maxs-ebike
00:00 Intro
00:20 Looks
01:34 Motor
02:36 Battery
04:21 Brakes
05:31 Gears
06:30 Extras
08:33 Essentials
09:17 Folding
10:21 Suspension
11:47 Controls
13:08 Riders
15:03 Ride Test
31:11 Final Thoughts
MAKE:
Cyrusher
MODEL:
XF690
PRICE:
$2,200
BODY POSITION:
Upright
SUGGESTED USE:
Neighborhood, Urban, Cargo, Commuting, Light Trails
ELECTRIC BIKE CLASS:
Class 3
WARRANTY:
2 Year Comprehensive
AVAILABILITY:
Canada, United States, Europe, Worldwide
MODEL YEAR:
2021
TOTAL WEIGHT:
65.76 lbs (with battery installed)
BATTERY WEIGHT:
7.04 lbs
MOTOR BRAND:
Lankeleisi
MOTOR TYPE:
Rear-Hub, Geared
MOTOR PEAK OUTPUT:
1,000 watts
MOTOR TORQUE:
80 Newton meters
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
12.8 ah
BATTERY WATT-HOURS:
615 wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
5 hours
ESTIMATED MIN RANGE:
25 miles
ESTIMATED MAX RANGE:
50 miles
DISPLAY TYPE:
S700 Advanced 3.7" LCD
READOUTS:
Charge indicator, Speedometer, Odometer, Trip Odometer, PAS Level, Time, Errors
DRIVE MODE:
Pedal Assist, 12-Magnet Cadence Sensors, Throttle, Walk Mode
TOP SPEED:
28 mph
FRAME MATERIAL:
6061 Aluminum Alloy
GEOMETRY MEASUREMENTS:
16.75" Seat Tube, 22" Reach, 31.5" Stand Over Height, 23" Minimum Saddle Height, 29.5" Maximum Saddle Height, 25.5" Width, 51.5" Wheel Base, 74.5" Length, Folded Size: 45" x 25.5" x 42"
FRAME TYPES:
Folding
FRAME COLORS:
Red, Yellow, Blue, Green
FRAME FORK DETAILS:
Coil suspension & hydraulic lockout and preload adjustment; 80 mm travel; 35 mm deformation;
ATTACHMENT POINTS:
Fender Bosses, Rear Rack Bosses
GEARING DETAILS:
27 Speed 3x9 Shimano M370
CRANKS:
Prowheel 170mm
PEDALS:
Aluminum with reflectors
BRAKE DETAILS:
Zoom Hydraulic Brake Levers with Motor Cutoff, Zoom Brake Calipers, 180mm disc brakes
SADDLE:
Lankeleisi Sports
TIRE BRAND:
Chaoyang 24โ x 4โ with Puncture-Resistant Liner
TIRE DETAILS:
Max Air Pressure is 20 PSI (1.4 Bar)
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Fenders + Rack Included, Kickstand, Assembly Tools, Integrated Headlight and Tail Light, Bike Lock, Air Pump
OTHER:
Locking Removable Battery Pack, 1.7lb 2 Amp Standard Charger, Max Total Weight 330lbs
cyrusher ebike electric bike review fat tire mtb emtb mountain bike hardtail 48 volt max distance folding yellow powerful fast performance cool amazing eye-catching
