Does it matter if there is a voltage difference between series connections?
Kadenmac
Hello,
I am building a 20s 12p battery pack and I have made the parallel packs already and when making them they were all the same voltage. Does that also apply when making a series connection. If so what is a safe voltage difference? I am using a bms by the way if that matters.
Thanks in advance.
harryS
You want all the parallel groups to be at the same voltage before you do the series connections. This allows you to start with a balanced battery,
harryS
Does the BMS have a balance function? It still takes a while if it does, of the cells are off by more than a quarter volt,
