EUNORAU 2020 FAT-HS: Same Frame Factory as Haibike,the Best 1000W Bafang mid motor Full suspension Design ebike
Here is the spec:
The 26" Fat Tire Model FAT-HS 1000W E-Bike
Specifications
MOTOR: 48V1000W BAFANG brushless mid-motor installed in mid-frame 160NM
FRAME: Aluminum alloy 19inch+Front&Rear Suspension
MAXIMUM SPEED: 28 MPH
BATTERY RANGE: 40 Miles
BATTERY CHARGING TIME: 4 - 6 hours
BATTERY TYPE: Lithium-Ion
BATTERY CAPACITY: 48V/14Ah SAMSUNG+Second Battery(Dual Battery Design)
BOX DIMENSIONS: (cm) 156 L x 32.5 W x 88H
THROTTLE: Thumb Throttle (power at your hand is always available)
DISPLAY: CDC6 LCD Display
HEADLIGHT: Front LED Headlight
TAILLIGHT: YES
REAR RACK: NO
Fender: NO
RIMS: 26 inch Black Alloy
SPOKES: Stainless Steel
TIRES: Kenda Krusade Sport Tires 26 x 4.0 with K-Shield Protection
GEAR SHIFTING: Shimano DEORE 9-Speed Freewheel
SHIFTER: SHIMANO DEORE 9-Speed
SPROCKET: 42T chain-wheel crank
BRAKES: PROMAX Hydraulic disc Brakes Front 180mm and Rear hydraulic disc Brake 180mm with Motor Cut-Off Sensor in Brake Handles
HANDLEBAR: Adjustable Stem for Comfort - Matte Black
ElevenAD
looks like a monster.........Frankensteins Monster! it appears to be pieced together from multiple bikes! other than that it seems kickass!
tomjasz
Same seller suggested the problEM solution was upgrading to a 52v when the 48v only showed 80% charge! Nuts! A BBSHD a real POS to repair or replace even a simple clutch!
tomjasz
it is 48V version on our bikes now, if you want compatible 52V, it need upgrade the software.
That's a real shame on you! A customer has no access to the firmware. How is it that BBSHD motors from everyone else can run both, 48V and 52V?
It is can run both. But 48V52V version will have issue when you use a 48V battery(display only show 80%), and some customer will complain our bike.
tomjasz
As well they should complain. I've seen your customer responses. No one wants an eBike without a working voltage display. All of my BBSHD report the proper voltage with both sizes of battery.
Why ship when firmware needs to be updated?
Will you share the files for upgrading firmware?
Ebiker33
Here is the spec:
Specifications
MOTOR: 48V1000W BAFANG brushless mid motor installed in mid frame
TAILLIGHT: YES
REAR RACK: NO
Fender: NO
Can you tell us what is the amp rating on the controller ?
John0407
This is what you are waiting for!!!!! New frame+new color
Can you guys tell us what is the height from bottom of tires (ground level) to the top of seat when the seat is at its lowest height? I have a short 28.5 inch inseam and want to know if I can touch-down comfortably when I am stopped and straddling the seat. Unfortunately there are hardly any choices for short riders who want to buy a full-suspension trail ebike.
Also, the cables under the Bafang motor look exposed and untidy in your 2020 model. Have you been able to "fix" this on your 2021 models? Finally, is there an option for 3-inch width tires to help extend range? Thanks very much, great price, I am putting this bike on my watch list.
Yes, please check the size from www.eunorau-ebike.com, we have update the photos and bike size.
the 2021 1.0 version have been fixed the wheelbase and the full suspension construction. we use the same frame factory as Haibike&Trek.
