Front fender was rubbing...
Denis Shelston
When I installed the front fender on my Téo Limited I put the upper bracket between the light and the fork brace. The screw is a tad short and I could not put the nut on the end of the screw if I put the bracket at the rear...
This effectively moved the fender forward by as much as 3/4". The net effect was that the bottom rear of the fender rubbed against the tire, as I found out.
Here's what I did, I moved the bracket to the rear, did not put the light right away, screwed in tight, the fender bracket bent to adapt. I then unscrewed put the light back and the screw was fine this time, 'cause the bracket had bent.
All is well now, no rubbing or chafing :p
