Hello from Kentucky and Florida! I’m really excited to meet everyone, and I’m also really excited to start a thread asking for your expert advice and guidance. I don’t currently (nor have I ever) owned an electric bike/trike. That’s why I’m here. It’s time to put my sadly ignored Specialized Hard Rock out to pasture, and find a proper electric trike for my next adventures, which will probably consist of trips to the beach, and the local grocer just down the road.
If you are going to the beach, you will want fatter tires for that.
If you are not used to a trike, you will hear everyone tell you that trikes ride different. If you are used to 2 wheeled riding, then your best bet is a TILTING trike. There are a couple kinds. Most are "tadpoles" which means 2 wheels in the front, on in back. But the Bintelli Trio is a standard one i front 2 in back "delta" style. When you get on/off or are at a stop, you can have the lever in the lock position and it won't tilt. So it acts like a regular trike. Then once you get going, you flip the lever to tilt and now you ride it just like a regular bike - you can turn easily, quickly and SAFELY by tilting into the turns just like you do on regular 2 wheelers. Then flick the lever again to resume locked upright trike mode. Also if you ride on uneven terrain on a regular trike, you are tosses side to side and can tip. With a tilting trike, you stay upright and the other wheels rock back and forth while both staying solidly on the ground. No tipping!
It has decent giddyup and a big lidded cargo basket. It is a solid trike as trikes go. Mid-range. But the tilting makes it my only choice.
