Help with Emojo Caddy Pro trike power (Reposted to Trikes/other)
TrikeRider
Reposting here from Garage
Hello,
About two years ago I was diagnosed with ALS. Through the pandemic our Benno Boost and RadPower City step through got us out and about. We put 1000 miles on each. I’ve recently needed to move to a trike. The Emojo Caddy Pro. I’ll repost the following in another thread, but here is my issue.
When I engage the pedal assist, the bike really takes off leaving me spinning my pedals faster than I’d like. Is there a way to reduce the power level so the assist is more subtle?
any feedback is greatly appreciated.
Timpo
The short answer is no.
(assuming that you have tried all power levels)
The bike you're referring to, Emojo Caddy Pro has cadence sensor, not torque sensor.
It's just a nature of cadence sensored ebike. It has this switch "on and off" feeling.
It will give you more assist than you need, but sometimes it won't.
Personally, I like cadence sensored ebike because I like getting pushed around, I enjoy zippy ebikes.
However, many people, including members here on EBR complained that cadence sensor scare them because it can be unpredictable.
As you described, depending on the situation, it will give you more assist than you want, because cadence sensor will detect if you are pedaling or not, that's it.
It doesn't detect how hard you are pedaling.
For the difference between torque sensor and cadence sensor, this video will explain to you better than I can.
Timpo
If you are, or if you know someone who is handy, you can get torque sensor.
This would require torque sensor (usually bottom bracket type, different than one in the video above) and possibly display and motor controller (if they are not torque sensor compatible)
Just letting you know that it is possible to get a torque sensor.
In addition, although I have heard that hub driven torque sensors do work very well, it is not quite as Yamaha or Bosch mid drive torque sensor.
I personally have ridden some torque sensored hub driven ebikes, like Stromer and BionX powered ebikes, and I felt pretty good.
TrikeRider
Yeah I watched a few comparison videos yesterday and understand more now. Thanks.
TrikeRider
The Benno bike has a mid engine with torque sensor. Much less lurching ahead. The Rad Power is a cadence sensor but rear hub and is very smooth in its acceleration.
Art Deco
Selinsgrove
Interesting that a torque sensor is an add on. Don't Bafang motors come with a throttle as a stock item? Can you use rhe throttle to get rolling smoothly, then start pedaling?
I have never ridden a bafang powered bike, so no experience with them, but throttles on motorcycles can be gentle enough.
Timpo
That's because Rad City has direct drive hub, whereas Emojo has geared hub motor.
Geared hub motors have more zippy characteristics, because of reduction ratio of (typically) 5:1 to 12:1.
Direct drive has no gear, so it is much less zippy off the start.
Timpo
Some Bafang powered ebikes do not come with throttle.
For example, my Juiced CrossCurrent Air did not come with a throttle.
Also in his case, throttle won't help.
The problem is that, the bike will just keep going.
Cadence sensor can only detect whether you are pedaling or not.
It doesn't even detect how fast & how hard you are pedaling.
Which means,
Let's say you are just going slow and pedaling at 7mph, but because cadence sensor detects that you are pedaling (the crank is moving, it doesn't matter how fast or how hard) the motor will keep propel and the bike will accelerate, as long as you are pedaling.
If it was a torque sensor, if you are going slow at 7mph, and barely putting pressure on the pedal, torque sensor will detect that and won't accelerate any further.
Therefore, if you suggest a throttle.. as you can see, throttle won't help. Because he is not complaining about bike not moving, it is the opposite, the bike just keeps moving without him pedaling fast/hard enough.
Art Deco
Selinsgrove
Ok. I think I understand. Sounds like an add on torque sensor might help if you can get a bike shop to install It.
