How does the Radrunner Plus, 500 watts in Canada Perform?
RichardQ
Canada
I'm on the market to purchase a Radrunner Plus e-bike. They say in Canada there is only 500 watts as maximum performance motor? How does that perform to compare with the 750 watts in the US?
Since I'm in Canada this is a concern for me. Does it have the zip or the go ahead as the Us model have? What is the maximum speed?
m@Robertson
The Rad motors, inside, are all 500w Bafangs despite the ones marked '750' that also have the enlarged plug. Internally they are the 500w core. All kinds of drama over this when it was discovered, and gets rediscovered every year or so by a new crop of owners. Rad justifies it by saying the motor is warranted to run at that wattage continuously, which I am sure is true.
Something else to be aware of: Motor wattage ratings aren't particularly meaningful. Wattage is a function of Volts (the battery) multiplied by Amps (the controller). So if you have a 48v battery (whose max voltage is actually 54.6v fully charged) and lets say a slightly below-average 20a controller, then 54v*20a=1080w. The waters get muddied when you start talking about whether the law applies to peak output or the largely-impossible-to-determine 'nominal', but you can bottom line it to this: Your motor is putting out more than 500w on a routine basis regardless of the label on the outside.
Think of motor wattage ratings as an indication of how much of a beating they can take. 500 < 750 so the 750 will live longer if throttled up a long, steep hill, all things being equal (I am ignoring the nylon gears for the sake of keeping things simple). And as a label that keeps you legal. Its not an indicator of the actual power your bike outputs. And as ElevenAD says... there is an upgrade path even for the USA versions that presumably have a little stronger controller themselves already.
RichardQ
Canada
Thanks for the infos. It's very well explained! I'll leave it a 500 Watts because in our region there's no steep hills.
