Illusion or Real
D
Deleted member 803
Guest
If you power on your Neo bike and then hold the plus and minus buttons simultaneously for 3 seconds you get the adjustment for tire size (I think). It goes up to 34 up from the default of 28. I set it on max and it changes the speed reading on the display with assist up to 25mph. Is this simply a function of changing the tire size setting with no real impact on speed?????
Peter
Unfortunatly it is only an illusion.
If you check the speed with gps you will see you are at the same speed but the LCD is way off.
I and many others have tried this :).
Would have been an easy speed hack though :).
