iZip Moda E3 First Ride Report & Updates
linklemming
Thank you for the updates Link. I agree that on the bottom mode it seems like it needs a lower gear ratio for going up hills. I too haven't figured out what the range is yet on the various settings. It seems to me for my commute to work, I will be using Tour mode mostly, with a stab to Sport on the very steepest hills and then back to tour at crest of hill.
How many miles do you have on the iZip Moda now? Mine has 180 miles. But, I have only been using it since March 27.
Thanks,
Rick
Probably around 600 or so miles on the Moda since I got it early March. I ride almost everyday 20-30 miles between 3 bikes (though mostly on the Moda since I got it). I ride for exercise and the Moda is perfect for that for less offroad oriented stuff although it handle gravel rides fine. As things dry out more I will be on my Bulls eMTB more.
Have an 11-36 10-speed Shimano HG50 cassette and new KMCx10e chain waiting to go on (I was cheap and didnt upgrade cassette when I went to 42t front chainring which would have probably been fine with the stock length chain, which has since been shortened...lesson learned).
Will install new cassette and chain when the new Marathon Plus MTB tires arrive mid-week.
I think using Tour mode exclusively with Sport on occasion is really the best setting. I plan on doing that on almost all my rides. I see no issues riding 40 miles like this (although most of my longest rides top out around 30-35 miles).
Will probably go to an XT derailler and 11 speed shifter and 11-42 cassette after I wear out the KMCx10e chain. Thing about where I live and the rides I do, lower gears always give me more ride options.
What a relevant thread for me! I've been debating myself between the E3 Moda (on sale for $2000 +$500 for a extra battery I would always want to carry) vs the CCX @ $2,500.
Im looking for a fast commuter, and it seems you prefer the CCX for that. My only gripes with Juiced is that they are online only, have a bad return policy (20% restock), and that I cant test drive it.
Ricky
Hi, How hard was it for you to replace the chainring? I have been having tons of problems with the chain coming off the front chainring, and I want to put a smaller chainring so that if it does come off it stays contained within the guard. Also, as per our old conversation, lower gear ratio would be good for climbing hills too. What tools did you have to buy and how hard was it to change the chainring?
Thank you,
Rick
Ricky
Hi, I took my bike to the e-bike dealer that I bought it from and had them replace the front chainring from a 48 tooth to a 46 tooth wide-narrow chainring. This completely fixed my problem of my chain coming off.
I have 1500 miles on my iZip Moda now and I love it. I will order a 11-36 rear cassette and put it on and along with the 46 tooth front chainring I think it will lower the gear ratios enough that it will be a lot better when using the low power setting going up hills.
I guess the next thing that I think would be awesome would be some way to adjust what the settings mean on the bike like Specialized with Brose motors let you do. I would love to be able to make the low setting slightly more powerful say 55% or 60% instead of the 50% that it is now.
Does anybody know how to do this?
Thanks,
Rick
JohnJ
Rick: Just curious why not just replacing the chain would have fixed the problem. Sound like a loose chain or stretched out (worn??) chain. I haven't experienced any chain issues so far. I like my Moda a lot but not as many miles yet as yours.
Ricky
Hi, the thing that fixed the chain coming off was going to a wide-narrow chainring. It must be an even number of teeth, but it grips the chain far better as the teeth and the chain mesh perfectly. It is a thing that came from the mountain bike world. The chainring is more complex as the teeth are different widths. A flat chainring only grips every other tooth correctly as every other link in the chain has a different width.
I have never had the chain come off since going to the wide/narrow chainring maybe 1000 miles ago. Before it came off occasionally, and then it was coming off almost once per ride.
Ricky
Hi, I know this thread is old, but for some reason it popped up and I thought I would reply to it. @linklemming
I now have a 46 tooth wide/narrow chainring and I put in an 11-36 tooth rear cassette and the KMC 10e chain. Love the combo, but I probably should have gone to an even smaller wide/narrow in the front. I didn't change out the front chainring, the bike dealer where I bought it did. He didn't think you could get a smaller front chainring because he thought the chain might rub on the chain guard and I didn't want to remove the chain guard.
So, I have 1800 miles on the iZip moda and I love it. It is now my go-to bike and I prefer it over my other rear hub drive bike. It is different than my other bike in that I find for maximum enjoyment you can't just set and forget like my other bike and you need to change the assist level up/down to match the terrain. It is second nature now and works great. Unfortunately, 2020 hasn't been good for miles and I was putting 2000+ miles on per year since 2017, but I only have about 600 miles this year. I just don't have places to go, or people to meet, or go biking with.
How are you liking your iZip Moda? How many miles do you have on it? Any issues? Can you put the 42 tooth ring and not have rubbing on the guard?
Sorry for so many questions and I hope you are doing well in this crazy year,
Rick
