"Lectric Xp - How I added a LARGER second battery to my Lectric XP" Upgrade Range Dual Parallel Extra Spare auxiliary More Powerful Battery Mod
Dex
I was looking for the best and easy way to upgrade add a second battery to my Lectric XP and came across this video on YouTube. (Not my video)
You can run your batteries in parallel (on) at the same time,
just make sure both are fully charge before connecting them together.
(From video description)
The vid they dont want you to see !!! So they make $ charging MORE for their weaker expensive batteries This shows you how simple it is to use a different battery IN 5 MINUTES !! I can go as far as 3 stock 10.4ah batteries that I would spend close to $600 w/chargers NOT INCLUDED to buy 2 extra lectric 10.4ah batteries to go as far as I do daily with this set up. You can buy a 48v 20ah for about $200 + or - and it comes with the charger so we charge both batteries at the same time if needed. First, " Lectric " is a awesome company with in my opinion a " 5 star customer service." The bikes are very good and a blast !! Some of You may have other ebikes with 48v batteries and you may want to use that battery you already own. I dont do vids but people kept asking me on fb HOW? What? Theres no other videos showing this easy way to get more range with less cost. Duel battery Lectric xp - This is how I added a extra second Battery - 48v 15.9ah aftermarket battery to my Lectric XP e bikes. It takes me about 5 min to do. Theres cheaper/better batteries and connectors out there than the ones I show you in the vid, which I bought over a year ago . My wife and I were in a hurry for more juice !!! This bike is going to her son in Minnesota !!! Im not advising anyone to do this, Im showing people how I did it to my Lectric ebikes. And I LOVE it. We use the bigger battery as our main battery as we like the speed and power that goes along with a bigger stronger battery. We do charge them both at the same time. This is how I do it. Share it and like it. Don't bother subscribing Im not out for popularity but to show the people this easy way to use a different battery. Lectric is a GREAT company with GOOD bikes !!!"
SHOW LESS
Dex
These are the items that are mention in the video, found everything except
(2PCS T-Plug Deans Style Male and Female Connectors 10inch 10AWG pigtail)
This should work below as a alternative (HobbyStar T-Plug Dean's M to T-Plug FM Adapter Extension Female Male RC battery)
Description: "T-Plug Male plug on one end and a T-Plug Female plug on the other end of 300mm of 14AWG silicone wire. Can be used as an adapter or extension wire."
HobbyStar T-Plug Dean's M to T-Plug FM Adapter Extension Female Male RC battery.jpg
UPP 48V 15AH 1000W E-bike Li-ion Battery Electric Bicycle NO Rear Rack Carrier
Same battery below but comes with a rear rack (Don't know if the rack will fit a Lectric XP?)
UPP Ebike Li-ion Batteries 48V 15Ah Alloy Case for 750W 1000W Motor +Rear Rack
Apex RC Products No Wire Ultra T Plug (Deans) Parallel Adapter Plug-3 Pack #1276
Apex RC Products No Wire Ultra T Plug (Deans Style) Parallel Adapter Connector Plug - 3 Pack #1276
Dex
These are How To Images from video you will need Electrical Tape and Zip Ties as mention in video.
Video by Lectric XP showing you how to get to battery connection, rest can be ignore doesn't apply to this upgrade.
Keehol
Thanks for posting and sharing with the community. Def one of the things missing from the bike.
Dex
48V 20AH batteries from the same seller.
48V 20AH 1000W Rear Rack Type Battery for 1000W Electric Bicycle LED Taillight
48V 20AH 1000W Rear Rack Carrier Li-ion Battery for E-bike Bicycle LED Taillight
(Battery below comes with a rear rack don't know if the rack will fit a Lectric XP?)
Dex
More information on dual batteries for Lectric XP (Not my video)
Lectric XP - Auxiliary Battery Wiring Harness in Detail"
Dex
This battery seems to be one of the more popular batteries as mention in above video "Auxiliary Battery" for Lectric XP dual setup and relatively cheap.
48V 20AH Li-ion Battery Bicycle 750W 1000Watt Scooter Motorcycle Hub BMS Power​
New🔥For 48V 250W to 1000W Motor🔥30A BMS🔥USA Seller🚀
ki11a
Unknown chinabrand batteries are generally a bad idea and can start fires much more so than trusted brands like LG, Samsung, Panasonic etcetc.
Is it worth a hundred dollars or so savings if your house catches fire? Doubt it.
Dex
I have heard this before but these Chinese sellers seem to sell a lot of these batteries on eBay and you don't see negative feedback like this battery burn down my house don't buy from this seller. Batteries listed here are from sellers many Lectric XP owners have brought from. In general I agree with you you get what you pay for. Buy and upgrade at your own risk.
Dex
What battery specifically and seller would you say is trusted website to get one these name brand batteries?
Just got that Monster Bluetooth Speaker Superstar S110 https://www.amazon.com/gp/product/B07YFYYJ53 and Bell Clinch Bottle Cages https://www.amazon.com/gp/product/B01BLXZXF6 that I saw on your Lectric XP today charging it now.
ki11a
heheh awesome, Im still using the same setup for music :p
In general I would say https://em3ev.com is a trusted source for good batteries that are a decent price, also https://lunacycle.com batteries but those are super expensive.
Oh and GrinTech is awesome https://ebikes.ca/shop.html
UPP used to be a good source, but Ive heard their quality has been really slipping so I dont recommend them
Dex
DUAL BATTERY CONVERTER - INSTANTLY DOUBLE YOUR RIDING RANGE!​
"Have you ever wondered about what to do with all your old ebike battery packs ?Watt Wagons is introducing an incredibly easy way to use your old battery packs and double your riding range. This converter will only work with two packs of the same voltage (e.g. 2x48v, or 2x52v). This converter will be available in May 2020."
(Batteries have to be the same voltage.)
  1. Compatible with 36v, 48v, 52v style batteries
  2. Battery capacity can be different - e.g. 11 ah, and 17.5ah
  3. Battery SOC (state of charge) can be different - e.g. one can be charged to 75%, and other to 25%
  4. Current range - up to 60A continuous discharge
  5. There is no dependencies on the motor
If the batteries have different SOC, the converter will use the battery with the higher SOC first.
Lorky
I wired up a 2nd LectricXP battery in parallel that I attached to the rear rack, made a huge difference. Pulling 20amps on the stock battery sags it so hard, all these companies provide batteries that are basically maxed out in their stock setup, they should be building batteries with some headroom like 30 amp capable but only pulling 20amp.
Dex
Agree, Lectric should be offering a larger battery upgrade or making it easier (kit) for people to add a second battery connected in parallel.
Dex
OliRC 2pcs T-Plug Dean's M to T-Plug FM Adapter 12inch 30cm Extension Female Male Wire for RC Battery(C42-2)​
  • Used as an adapter or extension wire
  • Male Deans to Female Deans Adapter Wire
  • Wire: 14awg 30cm
  • Quantity: 2pcs
2 PCS Deans T Plug Extension Cable Deans T Plug Male Connector to Deans T Plug Female Connector Wire Adapter with 11.8inch 14awg Silicone Wire​
  • T-plug Deans male connector to T-plug Deans female connector adapter extension cable with 11.8inch 14AWG silicone cable.
  • Wire Length: About 30cm / 11.8inch. Connector: male to female T-plug .
  • Product specification: excellent workmanship. It uses 14AWG high quality silicone wire and is suitable for high current power supply. It is convenient and quick installation, and can extend the distance of the ESC battery anytime.
  • Used when charging the battery on the board. Used when the ESC is too far from the battery compartment.
  • Package:2pcs * T-plug Deans male connector to T-plug Deans female connector adapter extension cable with 11.8inch 14AWG silicone cable.
Dex
FLY RC 4Packs No Wire Deans Parallel Connector 1 Female to 2 Male Deans
T Plug Parallel Connector Adapter for RC Quadcopter Multirotor
BNTECHGO 14 Gauge Silicone Wire Spool Red and Black Each 20ft Flexible 14 AWG Stranded Copper Wire
5 Pairs T Plug Connector Female and Male Deans with 14AWG Silicon Wire for RC Lipo Battery Cable Drone
Kuject 120PCS Solder Seal Wire Connectors, Self-Solder Heat Shrink Butt Connector Solder Sleeve
Waterproof Insulated Electrical Butt Splice Wire Terminals for Marine Automotive Boat Truck Wire Joint
Video
TACKLIFE Mini Heat Gun, 350W/662℉ Hot Air Gun with 6.56Ft Long Cable,
Overheat Protection Light Heatgun for Epoxy Resin Crafts
Shrink Wrapping Vinyl Wrap Wire Connectors Candle Making - HGP35AC
Titan 11477 Ratcheting Wire Terminal Crimper Tool for Insulated Terminals, Fixed Jaw Crimper
ELECFUN 200pcs Wire Connectors 10-22AWG Assorted Butt Splice Crimp Connectors,
Insulated Electrical Straight Wire Terminal Connectors Kit
3M Safety Scotch Electrical Tape, 3/4-in by 66-Foot, Multicolor
Dex
You can also mount a battery to Lectric XP frame using
3M double sided tape (If you prefer NOT to drill into frame).
As Youtuber DavidBrandNew https://www.youtube.com/channel/UCSKl3JFcdyIj04P6P_NJ2WA/videos
did. This way you can save Lectric XP rack for your other needs if needed.
This is the battery that was use in picture below mounted
to Lectric XP frame with 3M double sided tape.
According to him "mounted the battery bracket to the frame. Its super strong.
It won’t move at all." battery goes in the bracket.
VISET (U.S. Warehouse 48V 15AH Ebike Battery
Electric Bike Batteries Small Lithium
E-Bike Battery Pack Batterie for bafang 250W 300W 500W 750W Motors
Standard with 6# connector. (XT60). U.S. warehouse Delivery 3-7 days
E-bike battery is 48V 15AH, suitable for 200W-1000W motors
size:367.2*112*92mm (manual measurement, error +-5mm)
and the battery come with charger 2A , you don't need to buy.
3M Super Strength Molding Tape, 03609, 1/2 in x 5 ft
(This is the tape use to mount this battery/bracket to Lectric XP)
Dex
Ebike Battery Cover Waterproof, Dustproof, Wear Resistant Bike Frame Bag, Battery Bag for Hailong Battery/Dolphin/Tiger Shark/Jumbo Shark Battery​
