Max speed Juggernaut
Islander
At level 9 throttle only tops out at 30k per hour. Downhill the max speed I feel comfortable at is 40k per hour, started to wobble at 45k per hour.
tinasdude
Islander, if you change the wheel size in the display to 29, you will get more top end in throttle mode. Were you running lower air pressures when you were getting that wobble? Peddling or coasting?. I had some wobble at similar speed while peddling.Tire pressures were low because I had been off road earlier. Maybe tire compliance? I later coasted down several short hills. Held my line very carefully awaiting wobbles. None at 60 kph. Dead end roller coaster road I live on. Wouldn't consider doing that speed in traffic. 30-40 kph is plenty on the road with traffic
