Moscow arrived
Formernuke
My bike store finally got them in.
The moscow's came in but the pluses did not. So I decided to go with the regular moscow.
27.5 one, the step over seems pretty high thankfully I'm 6'2 so not an issue.
I'll post pics when I get the rack attached.
Any maintenance tips.
john peck
Why yes, If you weigh 240 or more you probably should swap out the stock schwalbe smart sams**. They are
comfy & roll fast,...but you will need beefier sidewalls & more psi. That will save both punctures &
spokes. Grip the cut-off brake when positioning the pedal for take-off & try not to bump throttle by
accident. This bike is goosey that way. With the moscow there is a need to keep the cables tuned
for stretch & temperature change, not a bad idea for tires as well, & things you´d need to do with a
regular bike.
**leoncycle is aware of this issue & said to fix, but I do not know if they´ve done so yet.
