Motor dies after 28 seconds.
ndbu2
I rode yesterday for the first time in a few months. The bike is a Eunorau Fat hd. The motor is a Bafang 1000 watt mid-drive.
I thought it could be the load but I tested it with the back wheel off ground and it did the same.
I can turn off the system, turn it back on and get another 28 seconds. Rinse and Repeat.
Does anyone have any experience with this or something similar? If so please tell me your solution.
Many Thanks!
Akrotiri
Europe
Take it to the dealer you bought it from , im sure should be a warranty offered by bafang.
Timpo
Ok well I’m sure bafang will replace his motor under warranty like Bosch, Brose, shimano and Yamaha do.
Is that how it work though?
For example, if your Specialized ebike has a problem, would you contact Specialized or Brose?
ndbu2
Thanks. I’ll begin trying to locate someone associated with Eunorau. It being a mid drive probably means a new bicycle. I hope they’re cooperative.
rich c
I'd say you are very optimistic. On-line sellers want to send parts. Sounds like a controller to me. I think you'll understand the advantage of buying from the LBS very soon!
Akrotiri
Europe
You would take it to the specialized lbs and they would contact brose for warranty work.
Edrummer
Many Thanks!
It’s the battery. Happened to me twice with my Brose S motor. Different bike........same symptom.
ndbu2
It’d be great if it were a controller. This bike has been a problem since day one. I have less than 5 miles on it and a little over $1000.00 in assembly and repair costs.
what’s the LBS?
Thanks for your reply!
Timpo
what’s the LBS?
LBS = local bike shop
Akrotiri
Europe
Isn’t that the truth!!!
Go to a local bike shop that sells ebikes&non-ebikes without your ebike , browse around make a small purchase. Look around at some of the bikes and strike up a conversation with one of the employees on your way out after purchase. Seeing that you made a purchase the employee will see that you’re a potential new repeat customer for parts, components, bikes& maintenance.
During the conversation mention in passing that you have an ebike that you purchased online that isn’t working atm. There’s a good chance the employee will offer to work on it for a fee if you verbally waive any responsibility to them if anything breaks. Since you’re ebike isn’t working you have nothing to lose.
ndbu2
Excellent idea! Thank you!
