my stans sealant setup.
fooferdoggie
So far the three tires I ahve it in I have not had a flat. I did have a flat in the one tire with slime so its hard to tell how ell it works. but with this simple syringe its easy to get stans in the tube. I have put 4oz in the tubes. I had stans syringe but it does not seal around the stem so makes a mess. this works well screws on and no mess at all.
Saratoga Dave
Tubeless setup for me. Let the air out of the tire, remove the valve core, and just pour the contents of a 2 oz Stan’s bottle into the valve. Replace the core, pump it up and go. Those little 2 oz bottles are perfect.
I just bought a new Dart kit and the spare kit with 5 extra darts this afternoon. Last night I wrote an entry here after one of the guys asked about tubeless flats, and sure enough today, a flat rear tire after going over some sharp rocks. Used my last plug and carried on. No good deed goes unpunished!
fooferdoggie
how can you pour it into a presto valve? way too small.
Saratoga Dave
The nozzle on the small Stan’s bottle fits right into the end of the presta valve. It’s small alright, but with the valve core removed it works fine.
fooferdoggie
I like the syringe bittern chance of back pressure squirting it back out or maybe I am just a klutz. this was the first time I did not make a mess from it. but it is a lot cheaper buying the bigger bottle. I think it is 8.00 for 4 oz in the little bottles this is 16 for. a quart. I had two tubes to put 40z in and two to put another 2oz in.
Saratoga Dave
A Schrader valve doesn’t have a removal core, does it? I think there would be no way to pour it in. Maybe I’m wrong, haven’t run Schrader in many years.
