Mystery part
DWEBiker
(Link Removed - No Longer Exists)This fell off my bike when i was putting it together , does anyone know where it goes?
Sorry court i dont know how to make the pic smaller.
Ravi Kempaiah
Canada
Halifax
The spacer that goes between your brake calipers. When you remove your brake calipers, you should put them in between to prevent the oil leakage if you accidentally press the levers.
Avid is a brake brand from SRAM.
Ravi Kempaiah
Canada
Halifax
When you install the brake housing/calipers, this thing will come off and rotor will occupy this annular space.
But when you remove the housing/calipers for bleeding or maintenance purpose, you should put this spacer.
