Neza HTR Review
Ennovation
Hey guys! We are back with another Ebike review, and this time we're taking a look at the HTR from Neza. The HTR is a street-ready Ebike that is a solid fit for small to medium riders, who don't plan on straying too far off the beaten path. Neza has a hip, city vibe, and I think this bike sits in that category perfectly. Thanks for stopping by to check out our reviews and as always, all the stats are below :)
Neza Official Website - https://nezabikes.com/
MAKE:
Neza
MODEL:
HTR
PRICE:
$800
BODY POSITION:
Forward/Upright
SUGGESTED USE:
Neighborhood, Urban
ELECTRIC BIKE CLASS:
Class 2
WARRANTY:
1 Year Comprehensive
AVAILABILITY:
United States
MODEL YEAR:
2021
BIKE WEIGHT:
34.5lbs
BATTERY WEIGHT:
5.2lbs (with saddle attached)
MOTOR BRAND:
XD
MOTOR NOMINAL OUTPUT:
350 watts
BATTERY BRAND:
Samsung
BATTERY VOLTAGE:
36V
BATTERY AMP HOURS:
5.2 (w/ 7.0Ah upgrade available)
BATTERY WATT-HOURS:
187wh
BATTERY CHEMISTRY:
Lithium-ion
CHARGE TIME:
4 Hours
ESTIMATED MIN RANGE:
15 miles
ESTIMATED MAX RANGE:
20 miles
DISPLAY TYPE:
Greyscale LCD, 3 Button
READOUTS:
Battery, Speed, Run Time, Odometer, Trip, Avg. Speed, Max Speed, Volume, Total Runtime
DRIVE MODE:
Speed Sensor, Throttle, Pedal Assist (5 levels)
TOP SPEED:
15 mph
FRAME MATERIAL:
6061 Aluminum Alloy
FRAME SIZES:
One Size
GEOMETRY MEASUREMENTS:
20.5" Seat Tube, 18" Reach, 27" Stand Over Height, 23" Minimum Saddle Height, 36" Maximum Saddle Height, 25.5" Width, 41" Wheel Base, 62" Length,
FRAME COLORS:
Black, White
ATTACHMENT POINTS:
Botype Cage Bosses, Fender Bosses, Rear Rack Bosses
GEARING DETAILS:
1x7 MicroShift Trigger Shifter
SHIFTER DETAILS:
Shimano Tourney Derailleur
CRANKS:
Unbranded 160mm
PEDALS:
FP, Plastic
BRAKE DETAILS:
JAK Hydraulic Callipers, 160mm Discs
GRIPS:
Foam, Non-Locking
SADDLE:
Unbranded Medium Cushion
SEAT POST:
Seat Post Tube Battery
SEAT POST LENGTH:
23"
SEAT POST DIAMETER:
46mm
TIRE BRAND:
Kenda
WHEEL SIZES:
20x2"
TIRE DETAILS:
40-65 PSI (2.8-4.6 Bar)
TUBE DETAILS:
Schrader Valve
ACCESSORIES:
Adjustable Kickstand, Integrated Taillight, Bell
OTHER:
1.2 lb Charger (2 amp)
