Panniers for City Kit (Racktime)?
Kris
I'm a little disappointed in the City Kit. I'm having a hard time finding panniers or bags that will work with this rear rack. Apparently the Racktime accessories will work with it, but when I try to find them for sale online, they are all discontinued!?!?
What has everyone else done? Am I destined to replace the rack? I like how it mounts, and would prefer to keep it if possible.
Ken W
I also use an Ortleib (City Roller). You will need to add the included insert in the two latch system as the City Kit rack has a smaller diameter rail.
Here is how the inserts and bag attaches to the rail.
http://ortlieb.com
Other brands may work but you should make sure there is enough adjustment to fit the City Kit rail system.
CptPalmer
They bags have a hook on the bottom you can get to hold on the frame. But they can also slide loose as well if you hit a bump or something similar. You can certainly try and use the panniers without the loops and pick them up latter if you want them. That is what I did.
