Pedal thread size for Radwagon?
skypup
Does anyone know what the tread size is for the pedals on the radwagon? Near as I can tell measuring the OD of the threads and converting to mm comes out as 13. something mm? Not sure if they use a standard metric thread or not. I want to add extenders to my pedals. Thanks in advance.
windmill
There are only 2 pedal thread sizes, 9/16" 20 tpi, and 1/2" 20 tpi.
Almost all contemporary bikes including all RPB bikes use 9/16" 20 tpi pedals,, no such thing as metric pedal threads.
mrgold35
I ended up putting larger and wider pedals with better grip spikes for my Radrover that fit my size 14 shoes a lot better.
skypup
I thought of that too. Just thought I would try this first. I don't really mind the pedal size but more length from the cranks seems like it will make a difference.
mrgold35
After thinking about it, my fat tire Radrover might be a little wider at the pedals to equal what you will have with the extensions on the Radwagon.
skypup
A friend is thinking of buying a Radover, his son just did. After riding mine the closeness of the pedals are his main concern. We're going to see if this addition helps,
