rad wagon handle bars - upgrade ideas ?
captain wavy
ive got 1000 miles on my wagon now , spokes have settled in after several tension adjustments & apex ziptie of spokes - old trick ! no other problems other that the really crappy handlebars , ive done a little grinding on handlebar mount adjustment to bring bars further back for more upright rideing position , my question can we replace bars with new rad runner bars , what bars fit head clamp / grips & accessories as the center is thicker than the ends etc for straighter wrist position & adjustability ?
WilliamT
I have a 2016 radwagon and the stem is 1 1/8 inch thick and the clamp size is 25.4 mm. If your going to put thicker 31.8 mm thicker mtb bars, then you'll need a new 1 1/8 inch stem that can clamp 31.8 mm bars. I replaced my bars with a Jones type handlebar so I had to replace the stem too.
John49
I needed my bars a little higher and back (closer) on my Radwagon. I went with a new stem and riser, big improvement! I ended up rotating the stem 180 degrees to get even a little closer. Perfect upright position now.
Delta Cycle Bike Bicycle Stem Raiser Pro Extender Head Up Handlebar Raiser https://www.amazon.com/dp/B007WEQIT4/ref=cm_sw_r_cp_tai_Y11VDbSW4325X
XCSOURCE WAKE 25.4mm (1") Cycling Bicycle MTB Mountain Bike Aluminium Alloy Handlebar Stem Black and Red CS385 https://www.amazon.com/dp/B01M1EOOBM/ref=cm_sw_r_cp_tai_k31VDb5JGKNJY
captain wavy
the question was - will radrunner handlebars fit radwagon , what are the bars that others have tried that will fit radwagon ?
captain wavy
awesome links - thanks !
