RadMini rear rack dimensions
Tom899
Can someone be so kind to measure the rear rack platform/footprint dimensions. I would like to know what size bags/trunks will fit.
Thanks!
Tom
Thom473
7" width side to side; 13" length from the front bend to the rear (but you can loosen a couple screws to make it longer (dunno how much longer since I haven't extended it); 15" from top to the wheel hub. The issue, though, is the tube diameter is 3/4" which will eliminate many of the panniers that are designed to clip on quickly (such as Bikase grocery pannier which doesn't fit for that reason).
