Radrunner Plus 500 Watts in Canada , compared with 750 Watts in U.S.A.?
RichardQ
Canada
How does the Radrunner Plus e-bike with 500 watts in Canada compare with the same e-bike in U.S. with 750 Watts? Is it more sluggish or is it as zippy? Do they have the same maximum speed? What are the comparisons?
AHicks
Same bike, but the 500w version is electronically limited to 500w output/available to the motor, where the 750w is limited to 750 or so. Same motor, same battery, different internal controller parameters.
From a practical standpoint, the 500 is going to be just as zippy at lower speeds. Where you see the difference will be when you point both bikes up a hill for instance. With 750w available, the 750w bike will have more climbing power.
If that extra 250w is important to you, or it became important at a later date, there are aftermarket kits available that would level the playing field, with increased performance available from EITHER bike! For more info on that potential, look into Bolton performance mods.....
RichardQ
Canada
Thank you very much for the infos!
RichardQ
Canada
Thanks for the video. Gave good information. I think that I'll will keep it stock because there is not that much of a difference in power for the type of bicycling i'll do.
For me in my area there is not that much hills and i'll use it mostly for leisure bicycling. Thanks again Timpo and I always appreciate all of your infos so if you have any more infos
I'll be glad to hear from you.
