Raleigh Sprite IE Fixer Upper
mikesova
A couple weeks ago, I came across what I think is a 2016 Raleigh Sprite Ie on facebook marketplace for 250$. I thought it would make a nice project and good ebike for my wife. Apparently the bike came with a wrecked motorhome at a dealership. It had some frame rash on it in spots, but overall it pretty good shape. The guy that had it after the the wreck, had changed the wheels/tires and rear derailleur and let it sit.
94952386_602521947020686_1926432135225278464_o (1) by mikesova, on Flickr
95787730_602520133687534_6393025688718278656_o (1) by mikesova, on Flickr
Fast forward, I ended up buying it for 200$. The chain was junk, so I immediately took that off and cleaned up the bike overall. I noticed that the 7 speed cassette was loosey goosey on the 8 speed hub, so I had to order a spacer for the cassette. I changed out the stem/bars with some I had from my fatbike, and ordered some other fresh parts to spice it up (pedals, grips, crank bolts, bottle cage, etc.)
IMG_1669 by mikesova, on Flickr
While I was working on it, I turned the pedals and heard the motor kick in, so I was pretty confident that it would work fine. am Once the new chain came in, I took it for a cruise . At first it seemed to work fine, you pedal and the motor kicks in and makes you go. I have never used a mid-drive bike before. I am impressed with the power, you get going 20mph pretty quickly.
The issue I'm having is that the crank slipping. When the bike is on a stand (battery and motor off) , and you spin the cranks with your hand, it turns the chain and moves the rear wheel, however, once you get on the bike and try to take off pedaling, the cranks slip and you don't get a solid connection between pedaling and turning the front sprocket. There is some connections, but its not right. My assumption is that something is stripped inside that's not allowing a good "hook up" between the two.
Also, when I turn on the battery, the screen flashes a couple random things that I wonder are codes? I don't have a manual so I'm not sure about them.
IMG_1634 by mikesova, on Flickr
IMG_1635 by mikesova, on Flickr
any info would be awesome. This is kind of a low buck project, so buying a new motor is probably out of the question, BUT, the actual electric motor is working fine, it seems to be the mechanical crank inside that is a problem.
Cool find. Raleigh service has been more "miss" than "hit" for me on the three occasions I've contacted them. But it may be worth your while contacting Tranzx and seeing if they have any advice or diagrams they can share.
I saw your other post so hopefully that will get some traction. I also noticed some reports of issues with this motor in 2016 that were corrected the following year, but weren't exactly the same as what you're describing.
FlatSix911
Silicon Valley
Congrats on your finding the Raleigh Sprite iE. Are you comfortable opening the motor housing to check for any mechanical issues?
Otherwise, I would recommend searching for a Raleigh dealer that is willing to work on the TranzX mid-drive motor and electronics.
From Court's review on EBR:
  • MOTOR BRAND: Currie Electro-Drive® (TranzX), Model M16GTA
  • MOTOR TYPE: Mid-Mounted Geared Motor
  • MOTOR NOMINAL OUTPUT: 350 watts
  • MOTOR PEAK OUTPUT: 500 watts
  • MOTOR TORQUE: 68 Newton meters
  • BATTERY BRAND: Samsung or LG
  • BATTERY VOLTAGE: 48 volts
  • BATTERY AMP HOURS: 8.8 ah
  • BATTERY WATT HOURS: 422.4 wh
  • BATTERY CHEMISTRY: Lithium-ion
  • CHARGE TIME: 5 hours
  • ESTIMATED MIN RANGE: 20 miles (32 km)
  • ESTIMATED MAX RANGE: 40 miles (64 km)
  • DISPLAY TYPE: Fixed Monochrome Backlit LCD with Adjustable Angle
  • READOUTS: Speed, Odometer, Battery Capacity (5 Bars), Assist Level (0-4), Range Estimation
  • DISPLAY ACCESSORIES: Independent Button Pad on Left
  • DRIVE MODE: Cadence Sensing Pedal Assist (Optional Button Throttle)
  • TOP SPEED: 20 mph (32 kph)
Ravi Kempaiah
It's normally the clutch that goes out.
Raleigh should be able to get you the parts. It would be best to approach them through a dealer.
Timpo
Error codeDescriptionDetection methodRepair
E00Display system
E0000Voltage detection error of the Display (5V)Logix diagnostics program - automatic testChange Display
E0001Voltage detection error of the Display (5V_SW)Logix diagnostics program - automatic testChange Display
E0002Voltage detection error of the Display (5V_SW2)Logix diagnostics program - automatic testChange Display
E0003LCD backlighting abnormal errorLogix diagnostics program - manual testChange Display
E0004Voltage detection error of the Display (5V)E-bike systemChange Display
E0005Voltage detection error of the Display (5V_SW)E-bike systemChange Display
E0006Voltage detection error of the Display (5V_SW2)E-bike systemChange Display
E0007Display EEPROM read/write errorE-bike systemChange Display
E0008Display LCD driver IC defectE-bike systemChange Display
E0009Light Sensor defectLogix diagnostics program - manual testChange Display
E01Controller system
E0100Voltage detection error of the Controller (5V)Logix diagnostics program - automatic testChange Controller
E0101Voltage detection error of the Controller (5V_SW)Logix diagnostics program - automatic testChange Controller
E0102Voltage detection error of the Controller (12V)Logix diagnostics program - automatic testChange Controller
E0103Light voltage output error of the Controller (6V)Logix diagnostics program - manual testChange Controller
E0104Motor control circuit defectLogix diagnostics program - automatic test1.Check Motor cable, 2.Controller, 3.Motor
E0105Voltage detection error of the Controller (5V)E-bike systemChange Controller
E0106Voltage detection error of the Controller (5V_SW)E-bike systemChange Controller
E0107Voltage detection error of the Controller (12V)E-bike systemChange Controller
E0108Light voltage output error of the Controller (6V)E-bike systemChange Controller
E0109Slope sensor detection errorE-bike systemChange Controller
E0110Motor blockedE-bike system1.Check Motor cable, 2.Controller, 3.Motor
E02AGT system
E0200Voltage detection error of the AGT (5V_SW1)Logix diagnostics program - automatic testChange AGT
E0201Voltage detection error of the AGT (5V_2)Logix diagnostics program - automatic testChange AGT
E0202Voltage detection error of the AGT (15V_1)Logix diagnostics program - automatic testChange AGT
E0203Voltage detection error of the AGT (5V_RE)Logix diagnostics program - automatic testChange AGT
E0204Voltage detection error of the AGT (5V_SW1)E-bike systemChange AGT
E0205Voltage detection error of the AGT (5V_2)E-bike systemChange AGT
E0206Voltage detection error of the AGT (15V_1)E-bike systemChange AGT
E0207Voltage detection error of the AGT (5V_RE)E-bike systemChange AGT
E0208Home point detection errorE-bike systemChange AGT
E0209AGT motor driver defectE-bike systemChange AGT
E03Motor system
E0300Crank dead point sensor defectLogix diagnostics program - manual testChange Motor
E0301Crank direction sensor defectLogix diagnostics program - manual testChange Motor
E0302Crank RPM sensor defectLogix diagnostics program - manual testChange Motor
E0303Chain RPM sensor defectLogix diagnostics program - manual testChange Motor
E0304Crank dead point sensor defectE-bike systemChange Motor
E0305Crank RPM sensor defectE-bike systemChange Motor
E0306Chain RPM sensor defectE-bike systemChange Motor
E0307Motor temperature sensor defectE-bike systemChange Motor
E0308Motor Hall sensor defectE-bike systemChange Motor
E0309Torque sensor defectE-bike systemChange Motor
E04Battery system
E0400Voltage detection error of the Battery (36V) from ControllerLogix diagnostics program - automatic testChange Battery
E0401Voltage detection error of the Battery (36V) from ControllerE-bike systemChange Battery
E0402Battery I2C Communication errorE-bike systemChange Battery
E0403Battery voltage out of rangeE-bike systemChange Battery
E05Wheel speed sensor system
E0500Wheel speed sensor errorLogix diagnostics program - automatic testChange wheel speed sensor
E0501Wheel speed sensor errorE-bike systemChange wheel speed sensor
E06Display button system
E0600"+" button defectLogix diagnostics program - manual testChange display button set
E0601"-" button defectLogix diagnostics program - manual testChange display button set
E0602"S" button defectLogix diagnostics program - manual testChange display button set
E0603"Power" button defectLogix diagnostics program - manual testChange display button set
E07AGT button system
E0700"AT/MT" button defectLogix diagnostics program - manual testChange AGT button set
E0701"Upshift" button defectLogix diagnostics program - manual testChange AGT button set
E0702"Downshift" button defectLogix diagnostics program - manual testChange AGT button set
E0703I2C communication errorE-bike systemChange AGT button set
E08Communication system
E0800Display MCU <> Power MCU communication errorE-bike system1.Check Controller, 2.Display cable
E0801Display MCU <> Motor MCU communication errorE-bike system1.Check Controller, 2.Display cable
E0802Display MCU <> AGT MCU communication errorE-bike system1.Check AGT, 2.AGT cable
E0803Display MCU <> Torque MCU communication errorE-bike systemChange Motor
E0804Display MCU <> All MCU communication errorE-bike system1.Check Display, 2.All cable
E09Light system
E0900Front light system errorLogix diagnostics program - manual test1.Check front light, 2.Light cable
E0901Rear light system errorLogix diagnostics program - manual test1.Check rear light, 2.Light cable
E10Cable system
E1000Voltage detection error of the Battery (36V) from DisplayLogix diagnostics program - automatic test1.Check Display cable, 2.Display
E1001Voltage detection error of the Battery (36V) from AGTLogix diagnostics program - automatic test1.Check AGT cable, 2.AGT
E1002Voltage detection error of the Battery (36V) from DisplayE-bike system1.Check Display cable, 2.Display
E1003Voltage detection error of the Battery (36V) from AGTE-bike system1.Check AGT cable, 2.AGT
*Bold font as an important error message
Timpo
  1. power/display button:
    • short press to switch on the system (do not push the pedal during 8 second count down)
    • short press to select different screens/functions:
      • SPD : actual speed
      • ODO : total kilometers
      • DST : trip counter
      • RANGE : remaining range
    • long press: switch off the system
  2. + button: press to increase power support mode
  3. - button: press to decrease power support mode
  4. S-button:
    • hold button: walk assist up to 6kmh
    • short press: enable/disable boost
  5. light sensor to automatically switch on/off the lights
  6. actual speed
  7. total kilometers
  8. trip counter
  9. remaining range
  10. service symbol (in combination with error code): contact your dealer
  11. battery capacity indication:
    1. 5 bars: 80% to 100% remaining capacity
    2. 1 bar: 20% to 10% remaining capacity
    3. 1 bar blinking: 10% to 5% remaining capacity
    4. 0 bars left: no support but there is still enough energy left to supply the lights for 3 hours
  12. only with AGT option: actual gear in Manual Transmission or in Automatic Transmission
  13. indication if walk assist or boost function is enabled
  14. riding mode: 1 to 3
  15. value of the selected display screen
Al P
You can find dealers by zip on the website and call them. I don't think there are too many. One I can recommend is Bloomfield Bike Shop in Bloomfield Ct.
FlatSix911
Silicon Valley
Any reccomendations for a Raleigh dealer? I doubt I have anybody local to me that stocks the ebikes.
You can also email Raleigh for support... hope this helps.
mikesova
I've got the motor out. Not a major feat, just needed the correct tools.
I'm trying to get inside it, to see if there is something obviously broken, but it doesn't seem like the case wants to come apart very easily. I've taken out the fasteners that seem obvious, but I'm not sure what I need to move forward. Any tips?
Untitled by mikesova, on Flickr
Also, haven't heard anything back from Raleigh, yet.
mikesova
This video provided some help:
I understand why the cases are on so tight, they are silicone glued on. Also discovered the 3rd screw that was hidden under the tranzx decal on the moon shaped cover.
I also found a post by someone who had a similar issue, took motor apart and discovered a broken woodruff key in the clutch.
https://www.reddit.com/r/ebikes/comments/gkizxq
Ravi Kempaiah
Mike,
My hunch was "broken clutch or worn out dog ring".
It's not often you see metal gears missing teeth and in such cases, you will find motor making weird noises.
The simplest solution in your case would be to get a replacement motor from Izip or Raleigh. Until early this year, they were selling Izip and Raleigh bikes with TranzX motor. So, they should have some spare parts.
Let's back this up a sec. I was rereading what you wrote originally, "The issue I'm having is that the crank slipping. When the bike is on a stand (battery and motor off) , and you spin the cranks with your hand, it turns the chain and moves the rear wheel, however, once you get on the bike and try to take off pedaling, the cranks slip and you don't get a solid connection between pedaling and turning the front sprocket. There is some connections, but its not right. "
Are both of these scenarios with the power off?
It's not clear to me how the chainring is driven, but I assume not directly via the bottom bracket spindle. Therefore I'm wondering if the 3-pawl clutch has too heavy a layer of grease applied, causing either the pawls to be slow to engage, or not seating fully behind the detents.
When rebuilding freehubs, there are "special" semi-fluid greases available, though proper grease can vary by manufacturer. I'd suggest -- just to test this theory -- scraping off the the excess white grease that's on their now, maybe even applying some lightweight lubricating oil to the pawl pivots and springs, and seeing if the problem still exists. If it works, break it all back open and apply a lighter weight freehub grease. In the problem continues, then at least you've eliminated pawl engagement as a cause.
mikesova
Yes it slips when the power is off AND on. Obviously when the power is on, the motor will drive the bike, but the cranks still slip if you pedal hard. I'll give what you're saying a shot.
mikesova
Just took it apart, hosed down the clutch pawls and the ring it’s supposed to catch in with WD40 and cleaned the grease out. I put it back together, same problem.
I tried contacting a bike shop reccomended above, no contact back.
hmm.
