Storage of the Bicycle Frame Vado or Como
B
BarryS
Guest
I have leave My Vado in the Garage over the winter : With The Battery removed does anyone cover that open area to keep dust or debris that might get in, out? I occasionally read posts about having to clean electrical connection areas : I'm wondering if anyone has purchased just the battery cover for cover purposes :
It's likely the Bike will remain in storage 3-4 months : As snow is quite often and usually heavy once it arrives : Is this something to even be concerned about ? Covering it with a Tarp will likely cause Moisture buildup : Since the Garage is attached : So gets warm enough to melt the snow brought in on My vehicles : Thanks
RTeremi
You could wrap it if you’re concerned about dust. If worried about moisture you could put a desiccant container inside the wrap.
